swing Pocket GPS Verifier
Posted: Wed Jul 18, 2007 9:38 pm Post subject: |
Does the 2720 support playing mp3 files? If so, it should work (maybe there was a problem with the filenames) - if not, your only option in the short term is that old beta of POI Loader and WAV files. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
tomthompson Frequent Visitor
Joined: 26/08/2003 15:43:37 Posts: 386 Location: Southampton, UK
Posted: Wed Jul 18, 2007 10:09 pm Post subject: |
The only time I have had spoken warning sounds on my 2720 has been with the Beta version that used wav files , and then only after I had used the remove POIs part first .
So if anyone finds out if the 2720 can use mp3 files let me know as well
_________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ? |
stevei Lifetime Member
Posted: Thu Jul 19, 2007 9:52 am Post subject: |
Quote: | The only time I have had spoken warning sounds on my 2720 has been with the Beta version that used wav files , and then only after I had used the remove POIs part first .
Which version of POI loader are you using? _________________ Steve I |
Posted: Thu Jul 19, 2007 7:29 pm Post subject: |
I am using the beta 2.04 that was on garmins site for us to play with
When they bought out the new version I went back to bongs , so now I have reverted to the beta version again _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
gazza01 Occasional Visitor
Posted: Sun Jul 22, 2007 3:03 pm Post subject: |
HELP PLEASE
could anyone point me in the right direction to have spoken camera warnings for my new garmin nuvi 200w? my tomtom speaks and is great and i really would be gratefull for any help on this,
many thanks
GAZZA |
Posted: Sun Jul 22, 2007 9:14 pm Post subject: |
I'm not sure you can have them - I believe the Nuvi 2xx series do not support playing mp3 files, which is needed for custom POI alert sounds. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Sun Jul 22, 2007 9:19 pm Post subject: |
The Beta POIloader mentioned earlier used .wav files for the voices.
:D _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
Posted: Sun Jul 22, 2007 10:08 pm Post subject: |
Yes indeed it did, and this could be a suitable short term solution. However, a few Nuvi 200 firmwares down the line, and a few new versions of POI Loader later, and you may hit problems with this untested combination. I suspect Garmin may revive the WAV support in a future POI Loader version, but until then it's best to move on and try to forget what we once had ;) _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Sat Apr 19, 2008 10:55 pm Post subject: Re: Help please - what am I doing wrong? |
CDK wrote: | used the new POI loader to transfer the POIs and MP3 (same names, etc) to my StreetPilot 2720.
Result? Back to the Bongs! No spoken warnings at all.
Reloaded the WAV files from before with the old Beta version if POI Loader and everything back to normal, speaking again..
So what am I doing wrong - any thoughts would be much appreciated |
My guess is that the 2720, which has no MP3 player capability, unlike the 2820, Zumo and some Nuvis, won't work with MP3. Probably means that you and I are stuck with the 2.4.0 Beta of POI Loader. _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
Posted: Sat Apr 19, 2008 11:55 pm Post subject: |
Quote: | My guess is that the 2720, which has no MP3 player capability, unlike the 2820, Zumo and some Nuvis, won't work with MP3. Probably means that you and I are stuck with the 2.4.0 Beta of POI Loader. |
This is indeed correct. The rules of thumb is a unit with mp3 player cabability can play mp3 alerts, other newer units can use the wav alerts (but need the Beta version of POILoader to load the wav alerts), but older units, such as the i3 can't use either..... |
