jaskel Occasional Visitor
Joined: Oct 16, 2005 Posts: 49 Location: Down Under People...Down Under!!!
Posted: Sun Jul 08, 2007 2:33 pm Post subject: TOMTOM GO 710 Custom POI Issue |
ok, i installed some custom POI like cameras and KFC etc, but as I approch them they are just red boxes even tho i transfered the bmp too...its weird and i want to get the emblem up on the screen, can anyone help me?
Also it alerts a speed or red light camera like 350 mtrs away and thats it, by the time u get to the camera u forgot about it, is there a way to warn 350mtrs away and another warning at say 100 mtrs?? i find it annoying that it wont do this.
thanks _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
Posted: Sun Jul 08, 2007 2:47 pm Post subject: |
Firstly there is a problem with the bmp file, did you download these POI files from this site? - if so I would try another download as they don't cost anything.
Do not re-name the POI files or do anything with them other than place them in the current active map folder. It is possible your download has become corupted so try another download.
The second warning when approaching a camera is possible by installing a second copy of the Speed camera database to the device, to do this you will have to re-name each ov2 and bmp file, I have used the following in the past:
pocketgps_uk_gatso_30.ov2
for the second warning these would become:
pocketgps_uk_gatso_30_1.ov2
All the files then go into the map folder, watch the total number of POI files though when doing this, there is a limit of 100 Custom POI categories, so keep a tally on the number of ov2 files you have in the map folder at any one time - Mike |
Posted: Sun Jul 08, 2007 2:49 pm Post subject: |
ok thanks but tried all that...still no bmp
also i dont want to do that re 2nd alert, there is over 150 camera locations and stuffed if im doing that for all of them... _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
RQ Regular Visitor
Posted: Sun Jul 08, 2007 4:01 pm Post subject: |
It sounds like you have more than 100 custom pois. Ver 6 TT software will only permit 100 - so you will have to remove some of your pois. This might be your problem. Check in Windows Explorer how many .OV2 files you have
Another option to the one mentioned in the previous post is to download the consolidated speed camera file - all camera types in one file. You could then set a warning at 150 metres for the cameras in this set. You would only have to do it once to get your second warning. _________________ RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219 |
Posted: Sun Jul 08, 2007 11:10 pm Post subject: |
nope, well under 100 poi, even if i clear it and load only 1 poi on there it still does it. _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
Andy_P Pocket GPS Moderator
Posted: Mon Jul 09, 2007 2:44 pm Post subject: |
Right.
ICONS:
1. Check the name of the POI files in your map folder. You should find two files for each: e.g. "healthy_eating.ov2" and "healthy_eating.bmp". If the two file names are not EXACTLY the same (apart from the extension) the icon won't show.
2. The .bmp icon HAS to be 22x22 pixels square otherwise it won't show (check this in a "paint" type program on your PC. If you got the files from a POI files website like here, this should be right already. Where DID you get them from, you haven't said?
CAMERA WARNINGS:
1. If you want the alert to be closer (rather than have a second one) just change the distance setting in the "Warn when near" set-up for each POI category (Change Preferences / Manage POI / Warn when near POI). Note this will NOT work for the TomTom supplied speed camera data, but WILL for any other POI including the camera data from here.
2. There is some confusion where you say Quote: | i dont want to do that re 2nd alert, there is over 150 camera locations and stuffed if im doing that for all of them | and then say Quote: | nope, well under 100 poi, |
The limit is 100 POI categories. To add a second warning, you don't need to change anything for every *location*, just add the category or categories again.
Having said that, I wouldn't bother using this method. Just adjust the warning distance as #1 above, and install a spoken warning from HERE which you won't forget about. |
Posted: Mon Jul 09, 2007 10:33 pm Post subject: |
ok, checked everything and all ok.
Man I hate UK camera warnings so bad.. gatso...just call the thing a speed camera.. so annoying. _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
Posted: Mon Jul 09, 2007 11:18 pm Post subject: |
"Thanks".
Gonna tell us what was wrong? |
DennisN Tired Old Man
Posted: Tue Jul 10, 2007 8:08 am Post subject: |
Andy_P2002 wrote: | "Thanks".
Gonna tell us what was wrong? | Or, for the benefit of the grandchildren "Magic Word?".
Now point him at somewhere where he can see the effort entailed in producing "gatso", so that he can do "speed camera" for himself!! Or suggest he could always disable that particular warning and have ding-dongs instead. _________________ Dennis
Two of them are obesiting!! |
Darren Frequent Visitor
Posted: Tue Jul 10, 2007 9:06 am Post subject: |
I wouldn't be too sure he was saying it was now working, could be that he was simply clarifying that he'd checked and the files appeared to be 'ok'? _________________ Darren Griffin |
Posted: Tue Jul 10, 2007 10:54 am Post subject: |
Ah.. possibly. Hadn't read it like that. |
Posted: Tue Jul 10, 2007 12:03 pm Post subject: |
ACTUALLY GUYS, before you all jump on the gratitude band wagon I was saying exactly what Darren said..
Oh and just for the record, if I got it working i would definatly thank you for the assistance...so hop along now ;) _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
Posted: Tue Jul 10, 2007 12:09 pm Post subject: |
jaskel wrote: | ...so hop along now ;) |
So you don't want/need any more help?
Lots of specific questions were asked in the various replies and lots of suggestions given and all we got was "ok, checked everything and all ok.". |
Posted: Tue Jul 10, 2007 12:14 pm Post subject: |
geez guys, i mean chill..see the ;) ;) at the end, it mean im joking..you know wink wink
geez
what more do you want me to tell you, all is ok, filenames are correct, files are all in!! not much more I can really do. _________________ Laser Pro Park Vs Prolaser II; http://www.youtube.com/watch?v=1AGObqXP2-4 |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Tue Jul 10, 2007 6:27 pm Post subject: |
jaskel wrote: | geez guys, i mean chill..see the ;) ;) at the end, it mean im joking..you know wink wink
geez
what more do you want me to tell you, all is ok, filenames are correct, files are all in!! not much more I can really do. | Patently obviously all is NOT OK, or you wouldn't be posting _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
