Pocket GPS World :: View topic - Loading peed cameras on Tomtom1 v2 Europe
rafletcher
PostPosted: Thu Mar 29, 2007 2:24 pm    Post subject: Loading peed cameras on Tomtom1 v2 Europe Reply with quote
Well I've sucessfully used the OV2 camera files on my iPaq, but now I have the new TT1 V2 Europe maps device I'm starting from scratch again, as I have to cope with Tomtom Home.
So directions please on, having got the unzipped files on my PC, how and where do I get them onto my TT1 V2.
Thanks in advance.
PostPosted: Thu Mar 29, 2007 3:01 pm    Post subject: Reply with quote
You can use Home, but as you understand the Windows Explorer method keep using this when installing POI from this site. Its just the same as you used to do with the ipaq - its easier to be honest - Mike
rafletcher
PostPosted: Thu Mar 29, 2007 3:10 pm    Post subject: Reply with quote
Mike
Thanks for that
So where do I load the OV2 and bmp files to please - presumably the "Western Europe" folder?
Privateer
PostPosted: Thu Mar 29, 2007 3:47 pm    Post subject: Reply with quote
Hi rafletcher,
That's correct! Smile
Don't forget about the .ogg files, which can also be placed in the "Western Europe" folder. Thumbs Up
Robert.
Garmin Camper 770 LMT-D
rafletcher
PostPosted: Thu Mar 29, 2007 4:03 pm    Post subject: Reply with quote
Privateer wrote:
Hi rafletcher,
Thanks for that.
Funnily enough I was waiting for a reply to this thread and reading about the .ogg files - but for now I think I'll take one step at a time! On my iPaq it was a bit tempremental, and although I expect this TT1 to be less so I'm not going to risk it until I understand better :D
tonys66
PostPosted: Thu Mar 29, 2007 4:12 pm    Post subject: Reply with quote
help info can be found here on cameras
http://www.pocketgpsworld.com/uksafetycameras-tomtom-ov2.php
ogg files and help can be found here
http://www.pocketgpsworld.com/tomtom-ogg-files.php
rafletcher
PostPosted: Thu Mar 29, 2007 4:19 pm    Post subject: Reply with quote
Thanks, I did know about that - it was where I got the info for my iPaq/TT5 setup. It was the TT Home bit that threw me, so I'm glad to find out I can still just use explorer to install the files.
Harpo
PostPosted: Mon Apr 02, 2007 7:32 pm    Post subject: Reply with quote
Hi guys, I'm new on here and not a little perplexed!
I have purchased TT ONE v2 Eu camera database from your site, but that's about it - no data - that I can see.
The first thing I did was to print the installation instructions.
Then followed all items - without issue.
Having downloaded, unzipped, transferred, and enabled, I was rather expecting to see hundreds of icons at camera locations.
But I have nothing.
I can insert my own locations, and be warned by a very convenient 'beep beep', but try as I might the only ones that are displayed are the three which I have inserted (and all too familiar to me)
Any ideas?
Thanks in advance for your assistance.
PS. I'm off to France on Friday, and time is getting rather tight.
Cheers,
Paul.
PostPosted: Mon Apr 02, 2007 8:37 pm    Post subject: Reply with quote
Have you zoomed in if you are simply looking at Browse Map? The icons don't all appear too readily until you get closer. In "Browse Map" .... "Options" have you ticked Points of Interest? Are you looking local to you - maybe you don't have many cameras in your vicinity.
Have you by any chance c**** up the icons? They are Bitmap files with the same name as the cameras except with BMP extension. It has been known for people to jigger slightly the BMP extensions, ending up with .bmp.bmp (doubled). So now look at it with Windows Explorer - set to show all files and extensions - and in your map folder you should have pgpsw camera files named e.g. "pocketgps_uk_gatso_20.bmp" and "pocketgps_uk_gatso_20.ov2". You didn't say which camera set you downloaded, so the filenames I've given may not apply, but anyway, there should be "pocketgps_uk_ something.bmp" and "ditto.ov2". If not, you've not got it right.
So give us a bit more information please. NOTE I'm not a TT ONE guru, just that most Tom Tom stuff works the same way.
Harpo
PostPosted: Mon Apr 02, 2007 10:21 pm    Post subject: Reply with quote
Fully
Yes
Yes
No jiggering here!
I have the following: pocketgps_europe.bmp and .ov2
I do note that the .ov2 file is tiny at only 12kb - does that sound right?
I may be a novice, but 12kb seems hardly enough to hold the phrase 'you're nicked', in a dozen different languages!
PostPosted: Tue Apr 03, 2007 6:40 am    Post subject: Reply with quote
What you have is the Mainland Europe Camera File. There are 400 locations in it, mostly in Germany and Spain.
You would have to zoom in quite accurately to be able to see any Icons.
The best way is to use Browse Map. Tap Find | Point of Interest | POI near you and select the Camera File. Just tap any entry and the Map will go to that location.
If you were expecting ALL the cameras of Europe in the File it doesn't work like that. The UK Cameras have there own, seperate, File.
PostPosted: Tue Apr 03, 2007 6:44 am    Post subject: Reply with quote
Yes
Where are you located? - if you are looking locally to youself and not finding any Europe cameras - have you tried zooming out then move the map into Europe before zooming back in?
A much faster way to find the cameras is Browse Map/ Find/ Point of Interest / POI in city, type Paris and from the list select pocketgps_europe (you might need to tap the right arrow icon to see the full poi listings).
Once the correct POI Category has been selected the device will list the POI locations, to see one displayed on the map simply tap it.
POI files are very small, the Europe file will only contain camera data from Europe, no UK based camera will be included in this file, if you want UK then please download/ install the other options available - Mike
PostPosted: Tue Apr 03, 2007 7:51 am    Post subject: Reply with quote
As you can see, the gurus get up much earlier than I (or go to bed later!).
For information, the UK camera POIs contain over 10,000 cameras compared with the Europe 400, so if you had downloaded those you would have seen some! The Europe file is I think, still in development, so has some way to go before it gets as good as the UK one. I found it to be accurate last summer, that is, what cameras it showed I did see at the roadside. But I was mostly touring for beauty, not speed, so I probably didn't go near too many.
Welcome to the forum and have a nice trip.
Harpo
PostPosted: Tue Apr 03, 2007 10:52 pm    Post subject: Reply with quote
Guys, you've solved my problem.
The problem was my interpretation. Fancy thinking the UK database was held within the Eu version.
I've now got all the cameras showing as they are supposed to.
Thanks a million.
Paul.
PostPosted: Wed Apr 04, 2007 11:04 am    Post subject: Reply with quote
Harpo,
we're still working on improving our EU database so whiule you're in france pleas do capture new locations and submit them in the normal way (via the map on the 'speed cameras' page)
we're also working on the software for releasing the international database in all the formats that we offer the uk one in too.
give us time ;)
