Pocket GPS World :: View topic - tom tom go710 HELP!!!
Goto page Previous  1, 2
PostPosted: Sat Mar 24, 2007 4:53 pm    Post subject: Reply with quote
In this case you have two options, purchase another memory card from a reputable supplier that has a good high speed capability the "Integral SD High Speed" from Maplins work fine in the Go devices and install your back-up to it, or wait until Monday morning and contact TomTom via the phone number (which you have got) - explain the card is dead, they should be able to sort you out, they have been asking for proof of purchase for waranty work so please have your receipt ready as a photocopy to send back as well - Mike
happypedal
PostPosted: Sat Mar 24, 2007 5:14 pm    Post subject: Reply with quote
thebinman wrote:
there's also the flash.fix thing can sometimes help:-
http://www.tomtom.com/support/index.php?Language=1&query=mac+files&FID=6178
hiya, i just tried the flash, but still no joy Sad
no maps found!
worth a try tho
happypedal
PostPosted: Sat Mar 24, 2007 5:23 pm    Post subject: Reply with quote
i've got three other sd cards a 512m , 1gb and a 2gb one sandisk and two vikings and none of them will work. do you t hink it's the SD card or the data or the TT?
PostPosted: Sat Mar 24, 2007 5:28 pm    Post subject: Reply with quote
Probably the back-up that is not intact to be honest, the folder screen capture you listed doesn't look good with some strange folder called .Trashes in it - can you locate the actual backup folder on the PC and grab a screen shot of that using Windows Explorer - the way to find the actual folder is via TomTom Home once this software is running select File/ Preferences click the advanced tab and file path to the backup will be listed, if the back up is bad there is little else you can do until Monday - Mike
happypedal
PostPosted: Sat Mar 24, 2007 6:08 pm    Post subject: Reply with quote
looks like im going to be phoning them monday, just one thing when i go tom tom home it displays in the bottom left hand column "MY GO 710" when mine is a go 510, is this right? Confused
cheers for all the help and ideas today
Smile
h.p
Page 2 of 2
22.054 (22 May 24)
