Pocket GPS World :: View topic - Q8 Garages Causing an 8MPH Speed Alert!
benjones
PostPosted: Mon Jan 08, 2007 11:34 am    Post subject: Q8 Garages Causing an 8MPH Speed Alert! Reply with quote
Hi there,
I've got a Nuvi 660 and have loaded parts of the POI database including the Fuel category. I've noticed that whenever I pass a Q8 garage I get an 8MPH speed alert - how exactly do speed alerts work as I though an "@" symbol had to be in the details for it to recognise an alert. Is it also using "Q" as a trigger do you think?
Ben
PostPosted: Mon Jan 08, 2007 5:12 pm    Post subject: Reply with quote
if there is number in the file name it will use that... i.e. if you had a csv file called gatso_30 then you don't need all the @30's in the actual file.
you may have to rename the q8 file name or just upload them in manual mode?
benjones
PostPosted: Mon Jan 08, 2007 5:31 pm    Post subject: Reply with quote
Cheers MaFt.
What do you mean by uploading in manual mode by the way?
PostPosted: Tue Jan 09, 2007 12:53 pm    Post subject: Reply with quote
in poi loader, on the same screen where you select the folder with the csv files there is the option of mph/mph and also automatic mode or manual mode.
manual mode allows you to state whether each category should have a proximity alert. bear in mind that you will have to do this for every single file and it can get a bit tedious...
auto mode looks for numbers in titles and sets proximity accordingly (or wrongly in the case of Q8!!)
