DonMac Occasional Visitor
Posted: Sun Dec 31, 2006 12:39 pm Post subject: changing the screen splash???? |
Hi, I have been trying to change change the "screen splash" to no avail, the only splash I get it the tomtom logo ( a pair of red hands).. I have followed all the instuction to the T but they still won't appear. I have put a letter in front of the original screen splash (gsplash)... used lower casing for the new screen splash (splash.bmp).. the size is correct at 240 x 320 ... can anyone tell me what I am doing wrong please.
Thanks in advance. |
DennisN Tired Old Man
Posted: Sun Dec 31, 2006 2:49 pm Post subject: |
Well, there are a couple of things you may have got wrong, for example the filename and the size!!
But first, what Tom Tom machime are you using, what application version. Then somebody with the same machine can put you right. _________________ Dennis
Two of them are obesiting!! |
Posted: Sun Dec 31, 2006 4:53 pm Post subject: |
Hi, using the tomtom Go500.... the file name is splash.bmp the file size is 240x320 application version is 5.410 GPS v1.21, Boot 3.30 if that is any help to anyone... also I cannot open the photo option when sd card is in the p.c.
Thanks. |
Oldboy Pocket GPS Moderator
Posted: Sun Dec 31, 2006 11:19 pm Post subject: |
The red hands are not the splash bitmap.
Have you rotated the bitmap 90 degrees to the right? You probably have as you said 240x320, but better to double check, and is it 24 bit?
Have you un-ticked Hide File Extensions in Folder Options? If not you may be calling it splash.bmp.bmp!
As you mention it, what Photo Option can't you Open? _________________ Richard
Posted: Mon Jan 01, 2007 9:11 am Post subject: |
Oldboy beat me to it (he usually does), 24 bit was the one magic item mentioned in a previous thread. The only other one I can think of now is to make sure it's in the root directory of the card (if you renamed the old one without moving it first, they should both be in the same, root, directory). _________________ Dennis
Posted: Mon Jan 01, 2007 9:00 pm Post subject: changing the screen splash???? |
Thanks for the help. I have now managed it.... I just removed the .bmp from "splash.bmp" & it now works. happy new year. |
Posted: Mon Jan 01, 2007 9:24 pm Post subject: Re: changing the screen splash???? |
DonMac wrote: | Thanks for the help. I have now managed it.... I just removed the .bmp from "splash.bmp" & it now works. happy new year. |
So you must have had it as splash.bmp.bmp as Richard suggested.
When I grow up I want to be as clever as Richard. _________________ Dennis
