Pocket GPS World :: View topic - C510D issues
C510D issues
peaton
PostPosted: Mon Dec 18, 2006 9:47 pm    Post subject: C510D issues Reply with quote
I have had my C510 a week now and I am not too happy. On the first day it worked fine as far as I could tell. I was able to navigate home using the preloaded detail map and was warned about speed cameras by the preloaded camera POI database. Later I went to show someone how it worked but when I turned it on it complained that no detailed maps were found that supported routing. I was able to load an additional map onto the SD card and I can now use it to navigate but get a warning that says can't unlock maps. I presume the gmapprom.img file is somehow corrupt. The preloaded Cylops sample POI files no longer work. I am on my second GTM21 thanks to the helpful people in the shop where I bought it but despite driving many miles over the last week I have seen no traffic information, the icon with the two cars remains grey. The light on the GTM21 does occasionally go green. Am I doing something wrong? I have seen various references to the traffic information being a bit flaky but it seems strange to get nothing.
portman
PostPosted: Tue Dec 19, 2006 1:06 pm    Post subject: Reply with quote
May be worth taking the unit back.
With regard to the traffic, the best thing to do is go in to the diagnostics menu and look at the signal strength. From the map screen press the 'speed' in the bottom left then press and hold the 'overall avg' button for a few seconds. This will bring up another screen, keep pressing next til you get to the GTM Status screen and look at the 'level'. You need i think a minimum of 7/8 to get traffic.
Samsung Mega
Tomtom 500
peaton
PostPosted: Wed Dec 20, 2006 12:45 pm    Post subject: Progress of sorts Reply with quote
Thank you for this tip. I have managed to get the traffic info working in my house with a signal level of 7. I assume that the units are not really suitable for use on the road in this country as observed by many other people on the forum.
I got the maps working by creating a new gmapprom.unl file and putting it in the Garmin folder on the unit. I have replaced the pre loaded Gyclops poi files with the latest demo camera database from Garmin and this works. I have also subscribed here to download the PGPS camera data. I still may try to return the unit as I did pay specifically to get the traffic data which is useless if I can only get it in my house.
portman
PostPosted: Wed Dec 20, 2006 6:37 pm    Post subject: Reply with quote
If you don't get traffic, turn it off then on again, quite often gets traffic that way.
Samsung Mega
Tomtom 500
peaton
PostPosted: Fri Dec 22, 2006 6:53 pm    Post subject: Update Reply with quote
Update:
I have yet to get any satisfactory results from the GTM 21. I have managed to get a signal in my car and receive actual traffic information, only however while stationary and fiddling about with the wire aerial. I see various references to extending the wire and also to splitting the car's FM aerial coax in attempts to get a better signal. Do these mods really work? I would rather make this darn thing work than fight for my money back. I do not want to mess around with the GTM 21's built in aerial if all I am going to do is ruin any chance or returning the thing. Any real world evidence the mods work would be valuable.
peaton
PostPosted: Wed Jan 03, 2007 11:41 pm    Post subject: Improved reception Reply with quote
I have managed to get reasonable reception on my C510 by extending the GTM21's aerial wire. Initially I attached the extended wire to the roof aerial in a similar manner to kelvin66, as shown on another post. This involved a small eye terminal that was clamped between the screw off aerial mast and the base. However I removed this one day as it was a bit untidy and found that the extended wire seemed to be sufficient just hanging inside car, at least in the areas I have driven recently. It consistently takes just over four minutes to capture a signal but then the LED remains green for most of my journey. I have not ventured up North since the mod so until then I will reserve judgement as to whether this is a real fix or just an improvement. Interestingly enough the traffic data, now that I do receive it, has so far been of little relevance to my journeys. The BBC traffic reports have substantially more information.
I have had a reliable signal from Swindon and surrounding areas, up the A420 as far as the M40 and on to Banbury.
Extending the wire involved carefully removing the plastic end off the aerial and replacing it with a small connector. I soldered a matching connector to the extension wire. The only purpose of the original plastic end appears to be for stopping the two windscreen suckers from falling off the wire.
When I am satisfied that this is the solution I will do a neater job of extending the wire and routing it around the car.
peaton
PostPosted: Tue Jan 09, 2007 11:39 pm    Post subject: Some progress maybe. Reply with quote
I have been experimenting a bit more with my GTM21. I bought a used aerial base for my car at the weekend. It is an amplified “bee sting” style aerial, similar to the one already installed. I drilled a small hole in the base plate beside the coax and fed a wire up to the amplifier. I have now put this on the car in place of the original aerial. The new wire is attached to my GTM21. My first observation parked outside the house is a slight increase in signal level with the amplifier turned on. It remains to be seen if it makes a significant difference on the road.
Incidentally, I did benefit from the traffic information yesterday, albeit a little too late. I was warned about a road closure on the A420. I got caught up in the tail back but was able to detour using the GPS and found an alternative route with ease.
footix2
PostPosted: Wed Jan 17, 2007 8:33 pm    Post subject: Reply with quote
I get strong Traffic signal on motorways and large metropolitan areas (such as Glasgow)
However venturing into my home county of Cumbria meant i got zero traffic. However this may be due to the fact there is no provider of TMC FM in the county.
HughGW
PostPosted: Mon Jan 22, 2007 9:38 pm    Post subject: Web Update to Traffic V3.90 might help Reply with quote
I have just updated my C510D using WebUpdater - it gave me a traffic software update to 3.90 and the signal strength referred to above has shot up in to the low 30's in my house on a hill in the Forest of Dean (not noted for brilliant radio reception). I shall be trying it out in the car tomorrow. This increase in Level ought to make a significant difference - I hope!
peaton
PostPosted: Tue Jan 23, 2007 7:33 pm    Post subject: C510 issue Reply with quote
I have applied the same update. I also get significantly higher signal level numbers. However I suspect this is just a different scale for the same information. My green light now turns orange at 16 instead of 4. I also am seeing a green light and no traffic data, something which was not the case before the update. I consider the update to be a step backwards.
peaton
PostPosted: Tue Jan 23, 2007 9:50 pm    Post subject: more info Reply with quote
I am seeing the green light come and go at levels well into the 30s. The unit has a green light now with no data. It is using channel 138 – 103.1 . When it cycles through the channels it always settles on 138. There are three other channels on the FM table. This is all in the house where I was able to receive data before.
peaton
PostPosted: Tue Jan 23, 2007 10:28 pm    Post subject: wrong FM frequency Reply with quote
That should be 101.3 not 103.1
