Pocket GPS World :: View topic - Mio & TMC
Mio & TMC
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12, 13, 14  Next
Sallyann
PostPosted: Tue Dec 05, 2006 7:08 pm    Post subject: Reply with quote
klystron_generator wrote:
it looks like C710 users with fully operational TMC are extremely fortunate
To avoid arguments over who gets to use the C710 we have just bought another one for the other car, and cloned all the settings. Now we can both avoid the jams :D
Sal
ernest_mio
PostPosted: Wed Dec 06, 2006 7:11 pm    Post subject: Reply with quote
Sal
Sal - in my mind the jury is still out on tmc - I was offered a 40 mile detour around a non-existant hold up this morning.
Going anticlockwise on the M25 and was offered a route that was clockwise.
The info is available but you still need to apply some thought before blindly following.
Sallyann
PostPosted: Wed Dec 06, 2006 7:21 pm    Post subject: Reply with quote
Yes, as with EVERYTHING that the GPS tells you. It's just advice, you take it or leave it. But if you don't see the information, you have no choice.
Sal
klystron_generator
PostPosted: Thu Dec 07, 2006 9:50 am    Post subject: Reply with quote
the whole TMC thing's a mess and trying to find information... Sad
spinkyfred
PostPosted: Sun Dec 10, 2006 2:39 am    Post subject: Reply with quote
it looks like C710 users with fully operational TMC are extremely fortunate Smile
Already posted on another forum without a real solution I have a Mio C710 and the TMC works but plugging the supplied aerial into the shared aerial/earphone socket cuts off the direction speech and device bleeps etc. Am I the only one with this problem as no one else seems to have mentioned it here. If I pull the aerial plug out a little bit it seems to restore the sounds to the C710 but it's not always reliable. Surely sharing the ear-phone socket with the aerial socket seems to be a mistake or is there something else I should be doing?
GPSBear
PostPosted: Sun Dec 10, 2006 12:41 pm    Post subject: Reply with quote
Sounds almost as if the plug is miswired.
Does the TMC work when the sound is cut off?
Does the TMC work when you pull it out a bit and get the sound back?
Sorry but your post was not 100% clear on that.
If you have a multi meter it might be worth sticking a pin into the lead and seeing which band on the plug is connected. Sal has posted the pin outs in another thread.
Mio C710 on MioMap 3.3
Sallyann
PostPosted: Sun Dec 10, 2006 12:48 pm    Post subject: Reply with quote
It does, or it could be that the socket has been damaged. Can you hear the messages/beeps on the supplied earphones when plugged in?
Sal
JohnRicketts
PostPosted: Sun Dec 10, 2006 2:24 pm    Post subject: Reply with quote
OK, the problem is that the plug is not engaging correctly. If not properly engaged (check the plug shoulder for poor machining or a lump of plastic or something). The Mio "thinks" that a headphone has been connected which is why it mutes.
I had the same problem whilst feeding mine via an arial split yesterday. If you can handle a bit of soldering, you can either replace the plug on the supplide arial (connecting to the 3rd contact from the tip) or do as i did and procure an arial splitter to feed it from the car arial. (Note that if arial is not passive you will need a de-coupling capacitor).
I've just posted this elsewhere, but the connections (from the tip) are:- left ear/right ear/TMC arial/shield-0v
John
JohnRicketts
PostPosted: Sun Dec 10, 2006 2:37 pm    Post subject: Reply with quote
John
Just hang on a mo before using this pin-out.....even though it works for me, Sallyann is disagreeing with it....wait till we've reached a qualified agreement.
JohnRicketts
PostPosted: Sun Dec 10, 2006 4:26 pm    Post subject: Reply with quote
John
OK have now investigated. I apologise fror muddying the waters. Sallyann is correct. The pin out is from the tip ;earpiece/earpiece/0v/TMC
the_pts
PostPosted: Mon Dec 11, 2006 5:26 pm    Post subject: Reply with quote
Hi All
Just had the following email from MIO
"Mio Technology Support
Dear Mr. / Ms
Thank you for contacting our Mio Technology Support Team.
The TMC function now is available all over Great Brittian.
Hopefully we could inform you sufficiently.
Kind regards,
Mio Technology support team. "
I'll try it tonight
Pete
klystron_generator
PostPosted: Mon Dec 11, 2006 5:30 pm    Post subject: Reply with quote
what system will you be trying the TMC on?
the_pts
PostPosted: Mon Dec 11, 2006 6:35 pm    Post subject: Reply with quote
C210
klystron_generator
PostPosted: Mon Dec 11, 2006 7:39 pm    Post subject: Reply with quote
i think we'll all be interested to hear how you get on
darthpaul
PostPosted: Mon Dec 11, 2006 8:17 pm    Post subject: Reply with quote
So does this mean they've bought a license or something and that TMC will work now with all Miomaps?
Page 10 of 14
