Pocket GPS World :: View topic - warning voices
warning voices
andy-c1
PostPosted: Fri Dec 08, 2006 11:27 pm    Post subject: warning voices Reply with quote
i am wondering if there is a way to have the warning voices (data.chk) for camera alerts to be placed on teh sd card and not under navigation ...... the reason i ask is because we have been given work pda that we have no access to the pda at allall i can do is get into the sd card ,so putting all my poi in is fine but i can't get my voices or camera alerts on ,so i was wondering if there can be a work around by placing them on the sd card
it seems to be the lastest version of tt5 5.210 (5430) map v562 ..cheap Censored wouldn't give us tt6
thanks
TomTom 5001
andy-c1
PostPosted: Fri Dec 08, 2006 11:28 pm    Post subject: Reply with quote
oops maybe i shouldn't have said teh B word plz edit Embarassed
TomTom 5001
PostPosted: Fri Dec 08, 2006 11:33 pm    Post subject: Reply with quote
Use the ogg file warning method instead, the ogg files go into the map folder of the memory card so this should give you what you want, there is a long (ish) thread HERE that explains how to do this and where to get the files from, although with no access to the PDA how do you intend loading the application? - Mike
andy-c1
PostPosted: Fri Dec 08, 2006 11:55 pm    Post subject: Reply with quote
it was preloaded for us with our work system (cognito) and they use baan for comunications with all the techs , only thing is it's bog standard system and i'm used to mine with all the bells and whistles .....
i'll look into it and see what i can do thanks ..maybe there is hope then
TomTom 5001
PostPosted: Sat Dec 09, 2006 12:00 am    Post subject: Reply with quote
Andy, if the application is pre-loaded the ogg warning method should work fine as it uses the memory card, if you intend putting the TT application on to it yourself you might struggle, or find your employer doesn't like you hard resetting the device to put it back to the original configuration, this would of course remove any software they had loaded - Mike
andy-c1
PostPosted: Sat Dec 09, 2006 9:54 am    Post subject: Reply with quote
thank you for the info i will try making some files
yup it's a work pda and it's t mobile qtek9000 ,so in other words they have given us a the top of the range pda and turned it into the bottom of the range pda which is really annoying
TomTom 5001
22.053 (15 May 24)
