Pocket GPS World :: View topic - To Get Proximity Alarm Warnings
Garmania
PostPosted: Fri Oct 20, 2006 11:53 am    Post subject: To Get Proximity Alarm Warnings Reply with quote
I have just successfully downloaded the camera database onto my Garmin Streetpilot c510. The cameras show up on the map as a red circle showing speed restrictions but I do not seem to have an option to switch on proximity alarms on my Garmin. Apparently the manual says this option only becomes available to switch on, once you have downloaded the Custom POIs which I have done, but in 'Sytems' my Garmin does not seem to recognise that these have been downloaded, so no Proximity Alarmis avalable to me.
Have I missed a trick here somewhere?
Border_Collie
PostPosted: Fri Oct 20, 2006 12:14 pm    Post subject: Reply with quote
Just a thought, but did you unzip the folder first and downloaded from the new folder to your Garmin?
Garmania
PostPosted: Fri Oct 20, 2006 1:44 pm    Post subject: Reply with quote
No I did not. I guess I need to get winzip to do that.
PostPosted: Fri Oct 20, 2006 2:39 pm    Post subject: Reply with quote
If you are using Windows XP on the PC simply double click the downloaded folder and it will open. - Mike
Garmania
PostPosted: Fri Oct 20, 2006 3:41 pm    Post subject: Reply with quote
Thanks. Yes, I have been doing that. So I will have to ponder this some more!
PostPosted: Fri Oct 20, 2006 4:21 pm    Post subject: Reply with quote
Which download have you tried to use with the device? You could also try downloading the database again incase the files have become corupted in some way - Mike
Border_Collie
PostPosted: Fri Oct 20, 2006 4:26 pm    Post subject: Reply with quote
With XP double click Zip folder, e.g. Oct10pgpsw-speed-cams.zip, to open it and then choose 'Extract all files', towards the top left, which will produce an unzipped folder named Oct10pgpsw-speed-cams. Use this one to install cameras to your device.
