Pocket GPS World :: View topic - GO 300 Menu Titles Wrong
thevectra
PostPosted: Fri Sep 01, 2006 9:37 pm    Post subject: GO 300 Menu Titles Wrong Reply with quote
Can anyone tell me how to get the menu titles back to match the icons? EG Add favorite says 'Turn off map display', but they are all jumbled
Tumbleweed
PostPosted: Fri Sep 01, 2006 9:54 pm    Post subject: Re: GO 300 Menu Titles Wrong Reply with quote
Try a reset (botton underneath) to start with.
Tw
thevectra
PostPosted: Fri Sep 01, 2006 10:08 pm    Post subject: GO menu titles Wrong Reply with quote
Hi TW, Pressing reset will not solve the situation as if I change the disc then everything is OK (I have different dics for different countries). I'm sure it is something to do with the limit to POI's on GO 300. Thanks for the reply.
peterc10
PostPosted: Fri Sep 01, 2006 11:13 pm    Post subject: Reply with quote
I assume you mean sd card not disc? Have you changed the data.chk file recently to get spoken camera warnings? If so the symptons could be caused by you using the wrong download for the version of your software.
Peter
HTC Sensation
Copilot for USA
thevectra
PostPosted: Fri Sep 01, 2006 11:53 pm    Post subject: Reply with quote
Hi Peter, you are correct, I did mean SD card.
I have now resolved, but not by nowing exactly how.
I hooked up both the working (menu) SD card and the problem menu card. I then copied accross all the files in the route dir from the good to the problem SD Card, overwriting all dup files.
It has worked and I can now pop over to Switzerland in the morning and find my way around.
Thank you, for it was you that gave me the idea of over writing the files.
Have a great week-end, Rick.
Eldar
PostPosted: Sat Sep 02, 2006 1:39 am    Post subject: Reply with quote
Probably a wrong tomtom.mnu file. Have you ever installed any third party apps?
