Pocket GPS World :: View topic - Destin6 says "Storage card has been removed" but i
gus779
PostPosted: Sun Aug 13, 2006 3:30 pm    Post subject: Destin6 says "Storage card has been removed" but i Reply with quote
Hello!
I have a Dell Axim x51v (ROM A012) with WM5 and Destinator 6 installed. Everything is on axim's memory, SD card is just for music. However, when I turn the Axim off and then on, Destinator 6 says that "Storage card has been removed and application will shut down". But SD card is there! Any ideas why this is happenning? I thought this was a Destinator PN issue, not one of D6. Any help? I was considering buying a bigger SD card and install destinator maps there, but now I'm concerned that I might sometime be lost as destinator is having issues with the SD card. Has anyone encountered this error as well? Any thought will be apppreciated.
Thanks,
Gustavo.
gus779
PostPosted: Sat Aug 19, 2006 1:41 am    Post subject: Reply with quote
Anyone?
jimbo_hippo
PostPosted: Sat Sep 30, 2006 1:02 am    Post subject: Reply with quote
gus
It looks like if your quoting ROMs then you're fully up to date. You're correct in saying it was a PN issue and they released an update to fix it (just seemed to delay the read) The fix did work though.
I really don't have the answer but since your post had tumbleweed blowing past it I thought I'd at least post my findings. With an SPV M5000 I get the same result so looks like the bug is back. I now run a car which leaves the power on when ignition off so this isn't an issue for me.
As a short term fix maybe a trip to maplins for a ciggie type socket, a bit of wire and an in-line fuse is the solution. A borrowed multimeter or 12V bulb and some of those piggy-back clips should be within the capabilities if a basic user - earth to something solid and you'll be fine) I leave my GPS reciever on charge and on certain occasions leave the device plugged in while in a locked garage (risky but true- put it under the seat with no cable trace) so battery drain shouldn't be an issue.
I seem to have spent the whole nght posting cynical comments about Destinator so I'll reserve my comments on the fact that this has re-appeared until a different date!
Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim
