Pocket GPS World :: View topic - Tom Tom One Speaker Problems
steve170
PostPosted: Fri Jul 07, 2006 11:47 am    Post subject: Tom Tom One Speaker Problems Reply with quote
Has anyone else had problems with the sound distorting on the One? I had this happen a few weeks back, but it eventually starting working again. Now it's at it again.
Whenever there's a spoken instruction, it just sounds like white noise/static. Doesn't seem to be anything wrong with the actual speaker, as it seems to correct itself after a while.
Any thoughts?
Cheers,
Steve.
CavesOfTQLT
PostPosted: Fri Jul 07, 2006 12:31 pm    Post subject: Reply with quote
Can't say I've heard my One sounding like white noise during instructions, though at times the sound can change slightly; slightly muffled I think best suggests the sound. It's as though a blanket has been put between the speaker and the listener and it normally only lasts the one instruction.
More worryingly on mine the spoken instructions seem to become intermittent at times. Sometimes they work and sometimes they don't, and it can be a reet PITA if you're in an unfamiliar location, necessitating me to keep looking at the screen for when I should do the next turn.
StanStill
PostPosted: Mon Jul 10, 2006 3:26 pm    Post subject: Reply with quote
I have distorted sound on my One as well. Not all the time but there is a buzzing on some words especially after the unit has been switched on for an hour or two.
timalloy6711
PostPosted: Wed Jul 12, 2006 12:43 am    Post subject: Reply with quote
i have the same problem the voices and poi alerts have gradually ground to a halt and the tom tom drum does not work at reset. do i need someone to take it apart and look at the speaker? this is def not a software glitch as i have copied files on to another sd card with same result
timalloy6711
PostPosted: Wed Jul 12, 2006 12:44 am    Post subject: Reply with quote
alix776
PostPosted: Wed Jul 12, 2006 12:54 am    Post subject: Reply with quote
i would advise against taking it apart as you will invalidate any warrenty on the device either go back to the retailer if with time frame (sorry not up on comsumer right myself) or try tomtom you will most likely have too send it off to be repaired
device Lumia 950 xl
timalloy6711
PostPosted: Wed Jul 12, 2006 1:15 am    Post subject: Reply with quote
it is out of guarantee ...who will repair it for me?
porndoguk
PostPosted: Wed Jul 12, 2006 5:55 pm    Post subject: Reply with quote
i had this problem,
i sent the unit back twice,
i found out if you have spoken poi alerts,
it causes the problem remove them before it completely knackers!
timalloy6711
PostPosted: Wed Jul 12, 2006 11:34 pm    Post subject: Reply with quote
i did have spoken alerts for cameras !! ! However there is a further development ...the voices work perfect :x through earphones, so i guess the external speaker is goosed? Evil or Very Mad Evil or Very Mad
CavesOfTQLT
PostPosted: Thu Jul 13, 2006 12:16 pm    Post subject: Reply with quote
Thinking back I'm sure the speaker problem only appeared after I downloaded and installed a few more voices...
Though I can't really see how this can be the reason for the intermittent voice instruction issue, I've decided that as I'm unlikely to ever use them I've removed them from the unit. I'll see how it goes.
steve170
PostPosted: Thu Jul 13, 2006 7:10 pm    Post subject: Reply with quote
I've never had spoken alerts for POIs. The only things I'd added were the software upgrade (V5.45?) and the speed camera database. I tried restoring it to the backup I made when it was first out of the box, but it didn't help.
timalloy6711
PostPosted: Thu Jul 13, 2006 9:07 pm    Post subject: Reply with quote
i called tomtom today and some amreican dude said my "one" is guaranteed for 2 years and they will collect and repair foc!
thebinman
Banned
PostPosted: Fri Jul 14, 2006 10:14 am    Post subject: Reply with quote
Have you tried these:
http://cgi.ebay.co.uk/Tomtom-One-Speaker-System-w-Integrated-Mount-sat-nav_W0QQitemZ260006456506QQihZ016QQcategoryZ75327QQcmdZViewItem
just got one to try out and it's very good!
No connection....etc
steve170
PostPosted: Fri Jul 14, 2006 10:28 am    Post subject: Reply with quote
Switched the TT One on this morning and the sound has suddenly started working again!
This is actually really annoying, as it suggests this could be an intermittent problem. If I send it back to be repaired now, they'll say there's nothing wrong with it!
timalloy6711
PostPosted: Sun Jul 30, 2006 1:29 pm    Post subject: Reply with quote
excellent mate...this could be exactly what I need as I cant be arsed sending my one over to Holland and maybe lost in post etc
22.052 (08 May 24)
