Pocket GPS World :: View topic - Garmin 2610 (Bmw Motorrad Nav II)
Mike1200RT
PostPosted: Fri Jun 30, 2006 11:03 pm    Post subject: Garmin 2610 (Bmw Motorrad Nav II) Reply with quote
I have just subscribed.
Are your speed camera downloads compatible with my Garmin 2610?
How do I put them onto my Mapsource System on my computer?
Thank you
Mike Davies
WiRED
PostPosted: Sat Jul 01, 2006 11:18 am    Post subject: Reply with quote
Hi Mike, welcome to the forum.
The 2610 cannot use the POIs directly as it is an older model. You have to use a Map Overlay with that GPS.
Select 'Garmin' in the first dropdown box on the Download screen, then choose 'Garmin GPSR Map Overlay' from the second dropdown. That will download a single .msi file which you need to double-click, then follow the instructions. Post back here if you have any difficulties.
Mike1200RT
PostPosted: Sun Jul 02, 2006 10:10 am    Post subject: Download for Garmin 2610 Reply with quote
Thank you for your advice.
I have downloaded this Garmin overlay but cannot load it into my Mapsource programme? It is Winzip and I tried opening it.
It tells me it is not in a correct format for Mapsource - I am using Mapsource 8.
Any ideas how I can add the Downloay to Mapsource?
Many thanks,
Mike Davies
WiRED
PostPosted: Sun Jul 02, 2006 6:22 pm    Post subject: Reply with quote
If you double-click the .zip file that should open it up and you should then see a .msi file.
Once you have done that just double-click on the .msi file. That should start the installation process. Mapsource doesn't come into the equation until after this install phase.
Are you using Windows XP? Or something else...
Mike1200RT
PostPosted: Sun Jul 02, 2006 8:38 pm    Post subject: Garmin 2610 Nav II Reply with quote
I am using Windows 2000 Professional.
When I open the .msi file from Winzip a message comes up saying my system may not be compatible with it and when I continue a load of odd symbols are shown ??
Any ideas?
Thank you
Mike Davies
WiRED
PostPosted: Mon Jul 03, 2006 10:23 am    Post subject: Reply with quote
Ah, it sounds as if you don't have "Windows Installer" installed.
The map overlay uses a feature called "Windows Installer" (sometimes called Microsoft Installer or MSI) to install itself. This is built into Windows XP. Earlier systems which don't have MSI can download it from Microsoft (its 1.6Mb).
Once MSI is installed on your system, it stays there and you won't get a complaint the next time you install the map overlay. It also enables you to uninstall the map if you wish by running the MSI file again, or from Control Panel/Add Remove Programs.
You can download the installer using these links...
Windows Installer for Win95, Win98, ME
Windows Installer for NT, Win2000
Mike1200RT
PostPosted: Mon Jul 03, 2006 8:15 pm    Post subject: Garmin Saftety Map overlay Reply with quote
Many thanks for your help - system now all up and running.
Mike Davies
WiRED
PostPosted: Tue Jul 04, 2006 10:26 am    Post subject: Reply with quote
Glad you got it sorted Mike. It should be a lot easier next month Wink
