Pocket GPS World :: View topic - poi's for navman 720
moswick
PostPosted: Mon Jun 05, 2006 2:57 pm    Post subject: poi's for navman 720 Reply with quote
i have downloaded speed camera file for navman and saved in a folder on desktop, when i try to install csv files onto 720 from this folder there are no csv files there
PostPosted: Mon Jun 05, 2006 6:35 pm    Post subject: Reply with quote
The Navman Files are ASC Files. They are Text Files and the Data is laid out the same as the CSV Files.
The difference is that the CSV File has a header, which Navman doesn't need, or use.;)
moswick
PostPosted: Wed Jun 07, 2006 2:52 pm    Post subject: Reply with quote
so how do i now install pois
Tim Buxton
PostPosted: Wed Jun 07, 2006 5:26 pm    Post subject: Reply with quote
Read the helpfile here. Although it was written for the Safety Camera database, it holds true for all custom POIs. Click on my www button for a link to a website containing some POIs.
Tim
moswick
PostPosted: Thu Jun 08, 2006 3:09 pm    Post subject: no files showing Reply with quote
thanks for your advice but i still have same problem, i save camera files to a folder on desktop then active sync my navman 720 then open smart st desktop 2006, when i clickon map then points of interest the box that opens only asks for csv files so as new camera database files are asc they do not appear in the box so there is nothing to import. i have had no problem importing poi's before with my navman 520 so i have some experience
Tim Buxton
PostPosted: Thu Jun 08, 2006 3:20 pm    Post subject: Re: no files showing Reply with quote
That's strange. The Desktop POIEditor has never specifically asked for .csv files before. My POIEditor for the iCN530 (not quite the same I know, but close enough) has (*.*) in the box, meaning that I can select any file, although only valid ones will be used. Try renaming the file and changing the .asc to .csv and see if that makes any difference.
Tim
moswick
PostPosted: Fri Jun 09, 2006 3:03 pm    Post subject: Reply with quote
thanks for your suggestion of changing file name to .csv it finally works.it seems with the new model 720 and i imagine 750 aswell its back to the old routine, open asc file in notepad delete first line lat and long and then rename as .csv file then poi editor finds files. thanks for you help tim
Tim Buxton
PostPosted: Fri Jun 09, 2006 6:41 pm    Post subject: Reply with quote
Well they use the same app as the 530 (or so Navman told me) and that app has no trouble reading .asc files.
Tim
