BrianA Regular Visitor
Joined: Nov 22, 2003 Posts: 91 Location: Washington, UK
Posted: Sat Nov 29, 2003 4:47 pm Post subject: Scary bug |
8O Just found a bug as follows:
Machine: XDA II
Software: TomTom 2
What it is: Checkboxes disappear in most areas of Settings (eg the checkboxes you should see on the System\backlight screen)
What causes it: The GPS app that comes with TomTom 2.
Other: This is intermittent, I've been into the GPS app 3x now with no problem. Equally I've had had it happen 3x. 2x I had to soft reset, 1x I had to hard reset !!
Looks from the Pocket PC 2003 Support forum that others have had this too, on iPaqs ...
Brian Abbott 8O |
lbendlin Pocket GPS Staff
Posted: Sat Nov 29, 2003 4:49 pm Post subject: |
I assume you are using version 2.08 of the TomTom GPS app. Can you try and test the old version 2.06 instead? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat Nov 29, 2003 5:19 pm Post subject: |
lbendlin wrote: | I assume you are using version 2.08 of the TomTom GPS app. Can you try and test the old version 2.06 instead? |
Yes, v2.08, should have mentioned that. Don't have v2.06 and to be honest I'm a bit leary about messing around trying to install an older build - I've not used PocketPC much but if its anything like ordinary Windows thta's a recipe for headaches ... _________________ Brian Abbott
Go 520 + Navcore 8
(was a happy PDA user until TT stopped updating the software) |
Posted: Sat Nov 29, 2003 5:37 pm Post subject: |
That's certainly up to you. Just for the record - version 2.08 is known to create more problems than 2.06 ... (like usurping the BT so no other BT program can run at the same time) _________________ Lutz
