Pocket GPS World :: View topic - HELP TTN2 Install Problems
thebears
PostPosted: Wed Nov 19, 2003 11:18 pm    Post subject: HELP TTN2 Install Problems Reply with quote
Having finally received my HP2210 and TTN2 software i am trying to install. The problems are:-
1) I install the disk to cd and run, installed code and then selected uk. After installing TTn2 software to pocket pc, using default locations on all accounts.
After this i the went to programmes TTn2 and selcted it came up with an error saying somtheing like missing files, re-install and the like, so i removed it from add/remove and then softreset, and then still had the icons on the screen.
2) Tried to re-install and then got icons with TTN2(2) and TTn2(3) icons!!
What is the way to install the software, desperate to get this thing running
Dale Sad Sad
lbendlin
PostPosted: Thu Nov 20, 2003 5:37 am    Post subject: Reply with quote
- remove all TomTom components from the "Remove Programs" list
- delete all TomTom related directories
- reformat the storage card if you can
- clean the My Documents folder
- if possible clean the registry (there are entries for TomTom in both HKLM and HKCU)
- remove the shortcut(s) in \windows\start menu
- do a soft reset
- install the application and voice file
- install the GPS driver
- install the map(s) - best not via Activesync but via card reader
This should normally get you going - let us know how it works out
Lutz
TomTom/TeleAtlas NAVTEQ
22.044 (24 Apr 24)
