Pocket GPS World :: View topic - quest heath robinson wiring
ninjabika
PostPosted: Sun Apr 02, 2006 6:17 pm    Post subject: quest heath robinson wiring Reply with quote
hi-ya all
got me a quest last week from halfords £150.00 can't be bad,
what i'm really after is some advice about connecting it to my bike (fazer 1000).
i know i could spend £50.00 on a powered cradle but i'm sure i've seen somewhere a cradle with the plastic clip on the top to retain the unit for about £10.00 i just don't know where, this cradle also hashole where you can clip the wires into the back.
now here's where the advice bit comes in , what i'm intending to do is with the car kit that's supplied opening up the unit and in there there is a pcb board which contains the gubbins to knock the voltage down to 5v, so what i was thinking is can i just take the cigarette lighter socket off and with the wires it leaves just connect to an ignition live on the bike, also the 2 wires that go to the speaker can i disconnect them and just solder on a female audio plug so i can plug earphones in , i'm enclosing a link to the pic so you'll see what i mean, any thought's ???
http://imagehost.darkernet.co.uk/i/speakerunit.jpg
Martin
PostPosted: Sun Apr 02, 2006 6:32 pm    Post subject: Re: quest heath robinson wiring Reply with quote
In theory this will work, couple of additional points though; consider fitting a fuse between the power wiring of the bike and unit, also you need to make sure water cannot get into it, salt water (road spray in winter) will very soon ruin the PCB.
Not too sure this will work, you might find the units audio output too powerful in which case it will overdrive the headset and distort the sound. If you try this make sure the volume is set to minimum before switching it on, if its too loud you could damage your hearing, or worse still fall of the bike if it makes you jump - Mike
ninjabika
PostPosted: Sun Apr 02, 2006 7:33 pm    Post subject: Reply with quote
mike
thanks for the reply, i was intending taking all the internals out and putting them into a weather proof box from maplins, as for the audio connection i had intended using the volume control on the quest unit itself
Martin
locksmith
PostPosted: Wed Apr 05, 2006 6:55 pm    Post subject: Reply with quote
Is it really worth the effort to have that bird constantly repeating herself straight in your ears?
In the car she's in the background if you need her, but on the bike it may become annoying!
I don't bother with it on the bike, just keep an eye on the distance to next turn - works for me.
Incidently the quest buzzes when she try's to talk to you and you are on battery power. Round town it's quiet noticeable and grabs your attention. At night the screen lights up and is very noticeable it's trying to tell you something!!
ninjabika
PostPosted: Wed Apr 05, 2006 7:56 pm    Post subject: Reply with quote
hi-ya all
i think i'll try it on battery first and see how i get on with it, obviously i won't know till i try
Martin
dandywarhol
PostPosted: Sun Apr 09, 2006 11:10 pm    Post subject: Reply with quote
ninja....there's a couple of PMs in your inbox answering your question to me.
I converted the Garmin speaker/cigar lighter power lead doohicky with some pics in a previous post. I also found that using a 9v battery with the Autocom is a waste of time as it only lasts around an hour Crying or Very sad
Garmin Quest|Ram Mount|Yamaha TDM900
At the cutting edge of technophobia
ninjabika
PostPosted: Mon Apr 10, 2006 9:00 pm    Post subject: Reply with quote
dandywarhol
hi-ya thanks for that (note to self check inbox more frequently)
funnily enough my ram mount turned up today , certainly looks dturdy enough to me, btw have you any more info on the breakout audio jack you mentioned.
Martin
dandywarhol
PostPosted: Mon Apr 10, 2006 9:56 pm    Post subject: Reply with quote
Hi Martin
Maplin do a similar plug - a 2.5mm Mono Chassis socket part no. HF78K
ninjabika
PostPosted: Tue Apr 11, 2006 8:28 pm    Post subject: Reply with quote
good man, thanks
