ukefc Occasional Visitor
Posted: Fri Mar 31, 2006 4:25 pm Post subject: PROBLEM COPYING SPEED CAMERA DATABASE TO SD CARD |
I have just downloaded the full set of March speed camera files. I already had a free camera download from Tom Tom that I installed. I deleted these files from the SD card before I started to copy the pocketgps files across.
When I selected the 23 files from the pocketgps download and tried to copy them to the SD card, I keep getting a message like:
"The file 'pocketgps_uk_mobile_70,ov2' cannot be copied or moved without losing its encryption. You can choose to ignore this error and continue, or cancel"
What do I need to do?
Thanks. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Fri Mar 31, 2006 6:58 pm Post subject: |
What OS does your PC use? Or it might be a Firewall issue.
Are you copying to the Device, or using a Card Reader?
Are you able to Copy any other Files? If so there could be a corruption in the download. _________________ Richard
Posted: Fri Mar 31, 2006 7:44 pm Post subject: |
I am on XP Pro. Will it be a firewall issue if I have already downloaded the files? I am using a card reader. |
Posted: Fri Mar 31, 2006 7:46 pm Post subject: |
I have just created a simple .txt file and tried to move that to hte SD card and I get the same message. |
Posted: Fri Mar 31, 2006 7:47 pm Post subject: |
If I ignore the message I can still open the txt file from the SD card. |
Posted: Fri Mar 31, 2006 9:43 pm Post subject: |
In that case, ignore the warning for the OV2 File. See if it is there in Manage POI.
If it is, it's not a problem and just your PC being over cautious.
If you have POIEdit, try to open the OV2 File while it's on your PC. It won't open a corrupt file. _________________ Richard
Tumbleweed Frequent Visitor
Posted: Fri Mar 31, 2006 10:27 pm Post subject: Re: PROBLEM COPYING SPEED CAMERA DATABASE TO SD CARD |
ukefc wrote: | I have just downloaded the full set of March speed camera files. I already had a free camera download from Tom Tom that I installed. I deleted these files from the SD card before I started to copy the pocketgps files across.
Thanks. |
You can ignore it. You will get this message if you have the volume or the folder into which you initially downloaded the files, set up as encrypted. Maybe all your disks are set up this way in which case you wouldnt normally notice. The "disk" on the TomTom isnt enrcypted hence the message.
IMHO overkill for home computing unless you want to make sure your porn is secure.
Tw |
