Pocket GPS World :: View topic - i3 switching off
i3 switching off
matb
PostPosted: Mon Mar 20, 2006 9:03 pm    Post subject: i3 switching off Reply with quote
having been an i3 owner for a couple of weeks i must say that the little fella (well margaret actually) is great. there was an initial problem, which i read about in another link a while back, that in the greyhound roundabout area of the a580 east lancs road in leigh lancashire the system would "switch off" i also had this problem. after speaking with garmin they suggested a software glitch was possible on a number of the 2.7 v8 systems. halfords exchanged mine with no questions asked. garmin suggested i downloaded the beta 2.8. i did and it cured the problem. in fact the system is now easier to follow as the voice prompts are made sooner than in the 2.7 guise. Laughing
zogman
PostPosted: Tue Mar 21, 2006 10:06 am    Post subject: Reply with quote
nice bit of info mate..thanks.
Aitch2
PostPosted: Tue Mar 21, 2006 11:50 am    Post subject: Reply with quote
Not switching off - but has anyone else noticed their i3 'pause' for around 5 mins either side of Southampton Airport on the M27?? Bizarre! 8O
'Countdown to turn' still updates - but the map just stays static - until it deigns to redraw once more...seems to do it each time I pass.
It's either some weird signal eminating from the Airport - or maybe some sort of map boundary inside the i3??
Aitch
Find Somewhere Else 090407: www.marillion.com
bumpkin
PostPosted: Tue Mar 21, 2006 12:10 pm    Post subject: Reply with quote
I think someone else had a similar problem near an airport, can't remember who or where but I do recall a thread about it somewhere.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
richard5
PostPosted: Tue Mar 21, 2006 12:23 pm    Post subject: Reply with quote
I work at an airport, and have my i3 on every time I go there without any problems.
Using Map V8 and software 2.7 for info
bumpkin
PostPosted: Tue Mar 21, 2006 2:00 pm    Post subject: Reply with quote
Do you have WAAS/EGNOS enabled, as it receives from ground stations might the radar or some other signal be messing with this?
Had a quick search on newsgroups and could only find mention of one guy on a motorcycle in Italy whose GPS suddenly shifted his theoretical position into the Adriatic regsitering a top speed of something like 2700 mph Surprised . This occured near an airport and was the only explanation he could offer.
Chas
Aitch2
PostPosted: Tue Mar 21, 2006 2:24 pm    Post subject: Reply with quote
Yes - this thought had occurred to me too...obviously, there's all sorts of EM spectrum near to an airport...
Still interested to hear from anyone else who regularly passes Soton Airport with an i3 tho...
Aitch
matb
PostPosted: Tue Mar 21, 2006 2:27 pm    Post subject: Reply with quote
don't know if it helps your situation but the map on mine did not freeze it just went blank as if switched off but without the 30 second countdown. this happened either in view map, navigate, battery, plugged into the car, gps or waas settings activated. even a full reset did not help.
have you thought of the beta 2.8 upgrade. the problem stopped for me when i did Question
707
PostPosted: Tue Mar 21, 2006 3:26 pm    Post subject: Reply with quote
Aitch
I have noticed mine (Mavis) pause a couple of times, the map stays in one place, (first time I thought it had locked up) but the banners at top of screen still change and speed camera warnings still sound. Not near any airports though once on Bluebell hill Maidstone and once on A289. Question
Very odd
Colin
bumpkin
PostPosted: Tue Mar 21, 2006 3:37 pm    Post subject: Reply with quote
I think anyone chasing crop circles is going to have problems Laughing
Chas
colpac
PostPosted: Tue Mar 21, 2006 10:55 pm    Post subject: Reply with quote
"there was an initial problem, which i read about in another link a while back, that in the greyhound roundabout area of the a580 east lancs road in leigh lancashire the system would "switch off"
That was me, so i will try the 2.8 update, thanks for the tip
matb
PostPosted: Tue Mar 21, 2006 11:03 pm    Post subject: Reply with quote
colpac
i have sent you a message check your inbox
matb
matb
PostPosted: Fri Apr 07, 2006 5:04 pm    Post subject: Reply with quote
2.9 is now out and the roundabout issue is actually mentioned as part of the upgrade
matb
PostPosted: Fri Apr 07, 2006 7:06 pm    Post subject: Reply with quote
went for a spin and the problem is solved Laughing
helterskelter
PostPosted: Tue Apr 11, 2006 3:23 pm    Post subject: Reply with quote
Was it the spinning that cured the fault, how many times round the roundabout?? 8O
eddie
22.052 (08 May 24)
