Pocket GPS World :: View topic - Navman Sleeve (Storage Card) and Ipaq
fogun
PostPosted: Sun Oct 26, 2003 6:16 pm    Post subject: Navman Sleeve (Storage Card) and Ipaq Reply with quote
I wonder if anyone has experinced this.
I have recently noticed that each time I put the Navman sleeve on to the IPAQ it does not recognise the storage card and takes a while before the menu is available.
One way raound this is to reset the machine(IPAQ) and then take out the CFCard and put it back in again. I have now done a hard reset, and upgraded to service pack 2. The behaviour is still the same. I have not experienced this before.
Product: Navman 3400, Ipaq H5400
onbashi
PostPosted: Mon Oct 27, 2003 10:38 pm    Post subject: Reply with quote
I too experience this problem and get round it in the same way, i noticed it when my unit was upgraded to v2.10.10 by hp
fogun
PostPosted: Mon Oct 27, 2003 11:39 pm    Post subject: Reply with quote
I can assure you it is not the upgrade, cuase I am on V 1.11.19 Rom revision. The sas thing is I donot know what causes it.
PostPosted: Tue Oct 28, 2003 11:09 am    Post subject: Reply with quote
I found this problem with the 3450 and my iPAQ 5450. However NavMan do say that you should softboot your PDA after connecting the sleeve.
I usually attach the sleeve remove CF card and then softboot. After the boot sequence I insert the CF card, and all is OK.
fogun
PostPosted: Tue Oct 28, 2003 6:16 pm    Post subject: Reply with quote
Thanks for you response.
Do you mean that each time you want to use the Navman Unit you have to take out the card, reboot the Ipaq and then insert the card again? I have got away with just doing a soft reset to use the unit.
In the process of soft resetting and taking out the battery, I lost all my data today.
Would it be possible to reformat the CF card? and does anyone know where I can get an utility to do this?
TigerMoff
PostPosted: Tue Oct 28, 2003 11:29 pm    Post subject: Reply with quote
Have a go at downloading this trial flash format software. I find it very useful when I have problems with my CF cards.
http://www.webattack.com/Shareware/software/swutils.shtml
PostPosted: Wed Oct 29, 2003 11:29 am    Post subject: Reply with quote
I doubt very much if these problems are related to the CF card as this happens with all my CF cards (8 of them) and all of these work perfectly in the 2210 and in the 5450 with CF Sleeve.
fogun
PostPosted: Wed Oct 29, 2003 11:27 pm    Post subject: Reply with quote
I am sorry to dissapoint you but I just used my Canon Digital Camera to format the CF card, re-installed the Navman Maps, now the unit is working perfectly OK. Laughing
onbashi
PostPosted: Mon Nov 03, 2003 8:13 am    Post subject: Reply with quote
hmmm, I wonder if it will work if I format the card using my card reader from within windows....
i'll let you know...
smith934
PostPosted: Tue Dec 30, 2003 11:05 pm    Post subject: Reply with quote
So, did it work via the card reader?
onbashi
PostPosted: Wed Dec 31, 2003 12:50 pm    Post subject: Reply with quote
Yes it worked fine, Defrag works aswell :D
22.044 (24 Apr 24)
