Pocket GPS World :: View topic - CP6 camera warnings
CP6 camera warnings
Goto page Previous  1, 2, 3, 4
Schouten
PostPosted: Fri Jan 27, 2006 9:08 pm    Post subject: ALK Respond Reply with quote
Back on topic
This today from Sunil at ALK
Thank you for contacting CoPilot Technical Support.
Apologies for the delay in responding to your email. With regards to the POI timing, we are aware of this problem and currently working on a fix for this problem. A patch will be available to resolve this problem. We do not have an exact date for the patch but please check our website for further information regarding this.
PONDEROUS
PostPosted: Fri Jan 27, 2006 9:41 pm    Post subject: Reply with quote
It is good to see that ALK are apparently coming to appreciate the value of communication. It is a pity, though, that it comes over a month after 15th January, the date originally given for the patch - and some mention of that delay in Sunil's communication would have been helpful. Hopefully, it means that they are making sure that all the issues are addressed before putting the patch on the website.
Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005
wayj
PostPosted: Mon Jan 30, 2006 9:04 pm    Post subject: copilot 6 Reply with quote
Could any body please tell me if a review of copilot live 6 has been reviewed by GPSWorld? if so were is it.
I am thinking of upgrading from version 5 or changing to tom tom 5 and would appreciate any advice.
Chorlie
PostPosted: Thu Mar 02, 2006 9:27 pm    Post subject: Reply with quote
Ok, Sorry I know this doesn't 100% belong in the thread, but having not got a reply in the Smartphone thread thought I'd ask in here.
I've installed, CoPilot Live 6 for Smartphoe onto my friends T-Mobile SDA II and all works fine, but I can't get the Speed Cameras to work, I've downloaded the single file version and installed as instructed, but there aren't any icon on the map & I don't get warned when passing any cameras.
I use the database with TTN5 and it works fine, anyone any ideas how to install it on to CoPilot 6?
Chorlie
If it isn't broken, play with it some more...
PONDEROUS
PostPosted: Fri Mar 03, 2006 9:16 pm    Post subject: Reply with quote
I think that the probem might be, Chorlie, that many of us haven't handled a Smartphone.
If it is anything like the Pocket PC version of CP 6, you will need to go into |Settings|Map and then check Enable for the POIs concerned. To get POI warnings, it is |Settings|POI Alerts and check all groups and sub-groups required. If that doesn't work (assuming the menus are similar) it presumably has to be your download.
PONDEROUS
PostPosted: Sat Mar 04, 2006 10:54 am    Post subject: Reply with quote
... assuming that the facility actually works on the Smartphone, that is...
Page 4 of 4
