Pocket GPS World :: View topic - Speech choppy in CoPilot 6
Weetobix
PostPosted: Fri Feb 17, 2006 4:50 pm    Post subject: Speech choppy in CoPilot 6 Reply with quote
Hey everyone
I've just got CoPilot 6 installed on my MDA Vario. Everything seems to work fine, but the speech is very choppy, ie. breaking up.
Does anyone else have this problem or know how to fix it?
Weet
PONDEROUS
PostPosted: Fri Feb 17, 2006 6:53 pm    Post subject: Reply with quote
I don't know if you are using bluetooth, Weetobix.
I use bluetooth audio devices and I get a problem similar to the one you describe on my Dell Axim X30, but not on my X50v.
I am trying to find time to see if it is a new ROM that I installed on the X30 (I can't remember if I had the problem before) as Dell's bluetooth gateways tend to be problematic. Is it possible that the MDA vario has similar issues?
Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005
Weetobix
PostPosted: Fri Feb 17, 2006 7:41 pm    Post subject: Reply with quote
i use bluetooth to connect to the gps reciever but not for anything else
PONDEROUS
PostPosted: Fri Feb 17, 2006 10:40 pm    Post subject: Reply with quote
That's worth knowing. Maybe it isn't bluetooth, then.
alix776
PostPosted: Fri Feb 17, 2006 10:47 pm    Post subject: Reply with quote
it dose it in smartphone to on a regular basis
device Lumia 950 xl
PONDEROUS
PostPosted: Fri Feb 17, 2006 11:37 pm    Post subject: Reply with quote
Presumably no bluetooth involved in your Smartphone setup, Alix?
alix776
PostPosted: Fri Feb 17, 2006 11:41 pm    Post subject: Reply with quote
nope just bt for gps and lots of crashes
device Lumia 950 xl
PONDEROUS
PostPosted: Sat Feb 18, 2006 12:23 am    Post subject: Reply with quote
Alix, thanks; that's what I thought. I suppose what hardware is in use is relevant, as it doesn't happen on all PDAs. Also, I don't remember it on either of mine with CP 5.
alix776
PostPosted: Sat Feb 18, 2006 2:05 am    Post subject: Reply with quote
cp5 smartphone was much more stable and crashed alot lessi cant even plan a rout over 100miles on cp6 at the moment
device Lumia 950 xl
H_O_D
PostPosted: Tue Feb 28, 2006 9:42 pm    Post subject: Reply with quote
I have the same setup as yourself only the O2 variant of the K-JAM (XDA mini S).
I very occasionally get the breakup of the text to speech, but not enough to annoy me. I think this was slightly worse on the T-mobile "tweaked" version of Windows Mobile (as I briefly had their package).
One tip I've discovered myself - make sure nothing else is running before starting up CoPilot! I've even re-assigned my "Explorer" button as a shortcut to Task Manager in order to make this easier. Do an "end task" on everything before you start CoPilot. It seems to be more reliable (or less UN-reliable?) if you do that.
I don't know if this is a quirk of my setup but I often find that "Active Sync" has started ITSELF and possibly there is some conflict between that and CoPilot?
One other "quirk" I've found (that you might be able to confirm as you have the same setup?) If I've had bluetooth DISABLED, start up CoPilot (which obviously then can't detect the GPS device) and only THEN load Comm Manager to start bluetooth, Comm Manager will fail to start bluetooth and more than likely hang the PPC! Not much good when you're already driving! Sad Another reason it's useful to have that shortcut to Task Manager! ;)
