Pocket GPS World :: View topic - GPSlim 236 Status
GPSlim 236 Status
NigelC
PostPosted: Sun Feb 12, 2006 9:55 pm    Post subject: GPSlim 236 Status Reply with quote
I have just bought a GPSlim 236 and have started playing with the settings using SIRFDemo and SP GPS View. The problem I have is not being able to monitor what status each of the settings is in. In particular I have set the Trickle Power mode in SP GPS View but the SIRF display continues to show continuous power. In the Trickle Power popup you can set the trickle power values but how do you return to continuous power unless this is just by setting the duty cycle to 100%. Similarly, setting the Trickle Power settings in SIRFDemo I cannot see any difference in the response of the GPS.
I assume the Factory Start set all these settings back to the defaults?
Is there any utility that can report the status of these settings?
Nigel
NigelC
PostPosted: Mon Feb 13, 2006 1:48 am    Post subject: GPSlim 236 Status Reply with quote
With a bit more poking around I discovered the Poll Nav Parameters in SIRFDemo which does allow me to see the current settings.
However, if anyone knows of a Pocket PC utility that can do this please let me know
Nigel[/quote]
22.053 (15 May 24)
