Newsletter
Luxury 4 Bedroom Villa For Rent In Disney Orlando Florida
Pocket GPS World :: View topic - Pocket PC 2003
Pocket PC 2003
Thud
PostPosted: Sat Sep 27, 2003 11:19 pm    Post subject: Pocket PC 2003 Reply with quote
If you are unsure whether or not to upgrade to PC2003 then I would suggest it is well worth doing, at least on an iPAQ 5450.
Using the same route that is used on the TTN thread "Route Calculation Time....", that is Land's End to John O'Groats, the route calculation time has dropped from 11 seconds (PC2002) to 7 seconds (PC2003). :D
Another function that shows noticeable improvement is the map re-draw time when zooming in/out or panning.
Thud
PostPosted: Sun Sep 28, 2003 10:27 pm    Post subject: Reply with quote
And the speech problem (occasional crackle/slowdown/slur) appears to be fixed. This problem on PC2002 gave the impression that the iPAQ was sometimes overloaded and didn't have enough processing capability but with the faster operating system the problem has disappeared.
PostPosted: Mon Sep 29, 2003 9:27 am    Post subject: Reply with quote
That is interesting. I have kept my 5450 at ROM 1.10 as It didnt work with my WiFi set up at 1.11. I may now review that and upgrade.
Only thing is I still need a PPC2002 system for testing.
I assume that although the crackling has gone (which I dont experience) that they have done nothing for the volume issue.
Editor, PocketGPSWorld.com
Thud
PostPosted: Mon Sep 29, 2003 1:21 pm    Post subject: Reply with quote
Volume is no different.
With PC2002 I had difficulty connecting using WiFi until I took the battery out for 2 seconds and replaced it (and I have occasionally had to repeat that procedure). With PC2003 I had the WiFi up and running in no time and using the internet is so much faster. I don't know if it is the WiFi connection that is faster or the screen re-draw but it is noticeably faster.
Colin M
PostPosted: Wed Nov 05, 2003 11:30 am    Post subject: Reply with quote
(HP3970 running copilot 3.5UK)
Just upgraded from PC2002 to PC2003 last night, and there is a noticeable speed increase.
I timed a route calculation form London to John O'Groats two or three times each way to get an average; was approx 26-28 secs before upgrade. After the ROM was updated the same route came down to 15-18 secs. A good 10 secs quicker. Map redraw is also quicker when zooming in and out.
I would recommend upgrading, but some people might grudge the 40 fee Sad
PC2002 is clearly not optimized for the X-scale processor, but PC2003 does help move things along faster. You just wonder if it's still not running to its full potential. Confused
19.062 (09 Jun 21)
Terms & Privacy
