Pocket GPS World :: View topic - POICapture utility
POICapture utility
ned1
PostPosted: Fri Dec 16, 2005 6:09 pm    Post subject: POICapture utility Reply with quote
Hi all,
I have a ttg 300 running 5.200. can I run the speed camera "POICapture utility" on this or will I have to update to 5.202 and if so where can I find the 5.202 update.
ned Wink
Oldboy
PostPosted: Fri Dec 16, 2005 8:20 pm    Post subject: Reply with quote
You will need to install 5.202 and you can download it by clicking on 'www' below.Smile
forky
PostPosted: Fri Dec 16, 2005 10:39 pm    Post subject: Reply with quote
I have installed poi capture now on 3 different types of tt and followed the instructions to the letter. All is showing normal when i press to capture new cam and tt states it has saved the file. But when i look at the file to upload it shows 0 dat which to me means it has not captured it.
Is anyone else having this problem Evil or Very Mad
Garmin Nuvi 2699lmt
Samsung Galaxy S9 (o2) contract
ned1
PostPosted: Fri Dec 16, 2005 10:42 pm    Post subject: Reply with quote
Thanks Old Boy,
I will up-grade to 5.202 and install the "POICapture utility" as there are two cameras near me that are not in the system.
thanks again
Ned Wink
PostPosted: Sat Dec 17, 2005 1:59 am    Post subject: Reply with quote
Don't forget you can save cameras manually too. Just store the positions in a POI category and email it to the camera guys.
Detailshere
lbendlin
PostPosted: Sat Dec 17, 2005 3:05 am    Post subject: Reply with quote
Reset the GO (eject and re-insert the SD card) and then try to do it again. Or, if you have more than one map installed, switch maps back and forth. There's an error in the SDK that will cause the behaviour you see.
Lutz
TomTom/TeleAtlas NAVTEQ
forky
PostPosted: Sat Dec 17, 2005 10:47 am    Post subject: Reply with quote
I have reset go as you suggest over a dozen times now and still same problem, it saves the file but does not reload the map and has a 0 dat file
Garmin Nuvi 2699lmt
lbendlin
PostPosted: Sat Dec 17, 2005 3:34 pm    Post subject: Reply with quote
ok, try this:
delete the 0 byte file, and then from within TomTom create a new POI category called "PocketGPSCameras"
Then try running POICapture again
Lutz
forky
PostPosted: Sat Dec 17, 2005 4:10 pm    Post subject: Reply with quote
Lutz
Still have same problem. 0 bit file
Garmin Nuvi 2699lmt
lbendlin
PostPosted: Sat Dec 17, 2005 6:31 pm    Post subject: Reply with quote
how much free space on the storage card?
Lutz
forky
PostPosted: Sat Dec 17, 2005 8:27 pm    Post subject: Reply with quote
277 Mb
Does it have anything to do with the number of poi categories??
I have the full set of cameras minus the continental ones
Garmin Nuvi 2699lmt
forky
PostPosted: Tue Dec 20, 2005 10:20 pm    Post subject: Reply with quote
Lutz
Any furthur advise please Question
Garmin Nuvi 2699lmt
lbendlin
PostPosted: Tue Dec 20, 2005 10:28 pm    Post subject: Reply with quote
- remove and replace the SD card
- from within TomTom create a new POI category called "PocketGPSCameras" (or verify it's there).
- Then add a POI to that category from within TomTom.
- Then verify the file size. Please report back.
Lutz
forky
PostPosted: Tue Dec 20, 2005 10:35 pm    Post subject: Reply with quote
Added new poi category as you suggested tt says stored
When I go to add a poi tt does not show the category pocketgpscameras
Garmin Nuvi 2699lmt
forky
PostPosted: Tue Dec 20, 2005 10:42 pm    Post subject: Reply with quote
I have all type cameras installed which ammounts to 27
Could this be the reason
If so, would it be better to just install the single file version Question
Garmin Nuvi 2699lmt
22.053 (15 May 24)
