Pocket GPS World :: View topic - holux sirf 3, great kit
humber
PostPosted: Thu Oct 20, 2005 8:23 pm    Post subject: holux sirf 3, great kit Reply with quote
hi, after months of trying to get my toshiba e750 working i have got there by buying a belkin bluetooth module and a holux bt 236 slim gps ,it took about 2 or 3 mins to sort out and took it outside and within seconds there where six satellites,good kit!. the only snag was when i did a soft reset it seemed to disconnect the bluetooth manager so i had to reinstalled the software, maybe if i had took out the module this may not happen? the only other issue is in map view, the icon of a plug with a red cross on it is flashing in the bottom corner of the screen, anybody any ideas if this can be removed,thanks
PostPosted: Thu Oct 20, 2005 8:33 pm    Post subject: Reply with quote
I'm taking a lucky guess as to what navigation software you're using here, TomTom?
Anyway the plug icon you refer to is there to indicate you do not have external power connected. You're battery won't last long without power so I'd reccomend you invest in a 12v adapter.
humber
PostPosted: Fri Oct 21, 2005 9:13 am    Post subject: power cable Reply with quote
hi darren, thanks for your reply i have the power cable now so i will test it out,thanks again.
exfive
PostPosted: Fri Oct 28, 2005 12:38 pm    Post subject: Re: holux sirf 3, great kit Reply with quote
Hi Humber, I've got the same setup but when I soft reset the bluetooth manager software is still there and all my settings are still there. Which operating system are you using?
Toshiba e750 wifi + Belkin Bluetooth CF card
Sysonchip Smart Blue Mini
TTN5, Destinator PN, Kingston 1GB SD
humber
PostPosted: Fri Oct 28, 2005 1:52 pm    Post subject: tt3 Reply with quote
hi, i did have windows 2003 o/s but when it was sent back to toshiba for a fault i noticed when i did a hard reset that they had put 2002 on it, tom tom 3 is on it and seems to run ok.
22.051 (01 May 24)
