Pocket GPS World :: View topic - Wont forget a route!!!
steve404
PostPosted: Thu Sep 01, 2005 2:18 pm    Post subject: Wont forget a route!!! Reply with quote
Question Guys,
After a recent nuisance when the battery on my Acer N35 went flat, I have had to re program all the camera databases and bmp and sound files, but never mind about that now.
My problem is that whenever I switch on Destinator 3 on my Acer as soon as it has gone through its start-up sequence, it will always appear with a route to my brother in laws house in Lincoln and my first task is to have to cancel that route before doing anything else. It works fine other than that, but it always reverts to this previously used route.
Is there anyway I can stop it from doing the same every time I use the Destinator 3 programme??
By the way Mikey, thanks for your past help with installation and I too cannot understand why your 'how to' post has not been made sticky!!
Steve
PostPosted: Thu Sep 01, 2005 5:46 pm    Post subject: Reply with quote
have a look at the file attributes - maybe the config file is set to read only.
steve404
PostPosted: Thu Sep 01, 2005 6:14 pm    Post subject: Sticky Route Reply with quote
Lutz,
Can you point me in the right direction to to the location of the config file please?
Steve
PostPosted: Thu Sep 01, 2005 6:34 pm    Post subject: Reply with quote
...\destinatorapps\destinator\destinator.ini
steve404
PostPosted: Thu Sep 01, 2005 7:04 pm    Post subject: Stuck route Reply with quote
Looked at that, the setting is highlighted as 'archive', so thats ok.
Steve
steve404
PostPosted: Sat Sep 03, 2005 4:18 pm    Post subject: stuck Reply with quote
Cheers Half,
I shall check when I get home.
I e-mailed Destinator and their suggestion was too make sure I hadnt left the unit in planner mode instead of destinate, I hadnt so still have the same route every time I switch the unit on.
Steve.
steve404
PostPosted: Sat Sep 03, 2005 9:23 pm    Post subject: Stuck Reply with quote
Tried the sd card it does not have the lock on, any more suggestions?
Steve
MikeyF
PostPosted: Mon Sep 05, 2005 6:08 pm    Post subject: old route Reply with quote
Steve
A bit drastic, but have you tried reinstalling the software.
Copy the camera database files to your PC.
Remove the sd card with the PPC on and reinsert.
The program should then kick into life and try to reinstall.
All you then need to do is copy the speed camera files back across to the PPC again.
Mikey.
ps. If this doesn't work drop me an email and we can compare individual files to see which ones have changed and correct this way.
steve404
PostPosted: Tue Sep 06, 2005 4:15 pm    Post subject: Stuck Reply with quote
Mikey,
Will try that and let you know, the device and program work ok, its just one o those annoying problems Smile
Steve
steve404
PostPosted: Thu Sep 08, 2005 11:52 am    Post subject: Stuck Reply with quote
Well after much correspondence with Destinator by e-mail, the problem, it appears has been solved, it appears to have been a glitch in the following;
To delete your history please go to : Start, Programme, File Explorer, my Device, Storage Card, Destinator Apps or Paradigm and now click on the map (country). Now click and hold the pen on the file "PREVIOUS" for 3 seconds and now click on Delete.
Your History is now deleted !
Following this advice the route that kept reappearing has now left the building.
Thanks everyone for their help...........Smile
Steve.
