Pocket GPS World :: View topic - TTN5 On T3 Voice Problems
cphine
PostPosted: Sat Jun 18, 2005 7:03 pm    Post subject: TTN5 On T3 Voice Problems Reply with quote
I have upgraded to TTN5 on my Palm T3.
Everything seems to have installed correctly with the exception of the voices. I have no voices installed, not even 'Jane' and have 9.2Mb free space on my SD Card.
Does anyone know how to manually install voices on a T3? If I use the installer, everthing seems to be fine but I can't access any voices at all.
Chris Hine
TuurG
PostPosted: Sat Jun 18, 2005 10:41 pm    Post subject: Reply with quote
Where did you install your application? Voices only work from the SD card, not from RAM. Since app and voices need to be in the same location, make sure you installed both to SD.
cphine
PostPosted: Sun Jun 19, 2005 8:38 pm    Post subject: Reply with quote
All installed on SD Card. I have remormatted 3 times now and still no voices. I can see the data.chk and data.vif files on the card.
Chris Hine
grovesey
PostPosted: Mon Jun 20, 2005 6:09 pm    Post subject: Reply with quote
Chris Hine
You have to install voices one by one as required from the main installation disc. Once the programs's installed then you choose the voices within settings/voices.
TomTom 5 running on a Palm T3, using a TomTom cable GPS.
Tazfiend
PostPosted: Tue Jun 21, 2005 12:21 am    Post subject: Reply with quote
Copy DATA05.CHK and DATA05.VIF into your /tomtom directory and you'll have Jane. (Works on Palm anyway).
SKYravefever
PostPosted: Tue Jun 21, 2005 1:33 am    Post subject: Reply with quote
I've the same problem with adding new voices downloaded from TT.com. By putting the two files in the /TT folder, do you mean that I should create a folder named "TomTom" or put it in the same folder that TT Maps are in (which is in a folder currently named something else)?
Tazfiend
PostPosted: Tue Jun 21, 2005 2:59 am    Post subject: Reply with quote
I already had a folder on my SD card called TOMTOM (so D:/TOMTOM). My map is in a folder called Great Britain Map (or something close, I don't have my Palm beside me right now).
I thought on the Palm you always got a "map name" folder and a TOMTOM folder. Confused
If you don't have D:/TOMTOM you could try creating it and dropping in the DATA05.CHK and DATA05.VIF files. I can't see it doing any harm.
SKYravefever
PostPosted: Tue Jun 21, 2005 6:05 pm    Post subject: Reply with quote
I'll give it a whirl when I get home. But you're right, there is a TT Map folder named by the region/area it covers, e.g. Great Britain, or in my case West USA.
SKYravefever
PostPosted: Wed Jun 22, 2005 6:12 am    Post subject: Reply with quote
Nope, no dice. Tried putting the files in three locations, none of them worked:
1) ~/West-Map/ (this is where the other files on the card are)
2) ~/TOMTOM (I created this folder thinking TT would recognize it as the default voice folder)
3) ~/TomTom (Same as #2, different caps)
frank11
PostPosted: Wed Jun 22, 2005 9:45 am    Post subject: Reply with quote
I have an HP rz1710 and I can find my data05.chk and data05.vif files
on the ppc MyDocuments/TomTom
Maybe you could try them there
Frank
TuurG
PostPosted: Wed Jun 22, 2005 10:10 pm    Post subject: Reply with quote
Voices should not be in the TOMTOM folder but in the VOICES folder.
linknet
PostPosted: Wed Jun 22, 2005 10:27 pm    Post subject: Reply with quote
You can install the voice files on the SD card.
To do that the voice files need to be in a "voices" folder in the root of the SD card.
However, this also requires a "tomtom" folder in the root of the SD card else the voices will not be found.
If you prefer "Voices" and "TomTom" with capitalisation it makes no difference.
bhulku123
PostPosted: Wed Jun 29, 2005 9:31 pm    Post subject: Reply with quote
I can not get it worling on my Palm T3. I formated sd card several times, hotsync several different voices, no luck. i sent tomtom support email yesterday regarding this and waiting for the reply.
Has anyone figured out exactly what the problem is? Did anyone get support from TT tech dept?
Please explain in detail what to do?
grovesey
PostPosted: Thu Jun 30, 2005 9:40 am    Post subject: Reply with quote
Shouldn't be experiencing the prolems you relate.
As fas as I remember, you load up the voices at the same time as you install the TomTom program onton your Sd card. One thing I should emphasise is that TomTom HAS to be installed on any new SD card you use - it is resident on the CARD and NOT the Palm itself!
grovesey.
grovesey
PostPosted: Thu Jun 30, 2005 9:42 am    Post subject: Reply with quote
Shouldn't be experiencing the problems you relate.
grovesey.
