Pocket GPS World :: View topic - TOMTOM 5 & O2 XDA IIi
Goto page Previous  1, 2
austen_wrx
PostPosted: Tue Jun 14, 2005 9:59 pm    Post subject: Reply with quote
alix776,
Right i've installed 5, but cannot get the cr100 gps reviever to work with it. I select "OTHER NMEA DEVICE", 4800 baud rate and com 1 (as on tt3) but it just keeps saying "no gps device". I've left it for 15 minutes while stationary and still nothing Sad
alix776
PostPosted: Tue Jun 14, 2005 11:27 pm    Post subject: Reply with quote
you need to have the cr100 powered up via the car lead and then do this
START > SETTINGS >CONNECTIONS > BEAM uncheck receive all incoming beam then set up the gps again ie
start tomtom tap the signal bars then do the same in the route summery screen this will take you the gps screen select configure then other wired gps set baud rate to 4800 then select com1 then select done
device Lumia 950 xl
neil54
PostPosted: Wed Jun 15, 2005 7:41 am    Post subject: Re: Help o2 xdaIIi, keeps hanging with TTN5 and traffic Reply with quote
atherda wrote:
I can get TTN5 working fine with the BT, I can get weather and map updates etc. no problem, but everytime I try to update traffic it freezes the xda. This is a real pain as I have to do a soft reset each time.
Any ideas much appricated, I am still awaiting a responce from TomTom support.
Do you keep GPRS "on" all the time? If not, you may have fallen foul of the GPRS reconnect "bug" in the XDA 2i, which in some circumstances prevents reconnection to GPRS, if it has been connected, then disconnected. Only a soft reset, or switching Flight Mode on then off again clears this problem, but it reappears after the next GPRS connect/disconnect cycle.
If you try connecting GPRS, then starting TomTom and updating Traffic before any other GPRS activity, does it still freeze?
austen_wrx
PostPosted: Wed Jun 15, 2005 9:52 am    Post subject: Reply with quote
gggrrrrr!! still not working!!!!! The xdaIIi is very close to being sent back and getting ot swapped for a xdaIIs
atherda
PostPosted: Thu Jun 16, 2005 6:19 pm    Post subject: Re: Help o2 xdaIIi, keeps hanging with TTN5 and traffic Reply with quote
Yes unfortunately it makes no difference. Traffic starts but the green arrow stops and only a soft rest works.
I_Need_Help
PostPosted: Mon Jun 20, 2005 10:44 pm    Post subject: Reply with quote
I asked tomtom if the XDA2i is supported and they said yes with a BT GPS.
johnwx
PostPosted: Tue Jun 21, 2005 7:27 pm    Post subject: Reply with quote
OK I'm running XDA2i TT5 and ClipOn BT GPS after performing the reg hack on this forum all works ok with no problems.
Once you have set up the XDA2i it runs ok but a real pain in the Ar5e to set up. not TomToms best effort
Johnwx
Page 2 of 2
