TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Jun 08, 2005 11:08 pm Post subject: |
yeah, we are one hour ahead here on this side of the Channel 8) |
joni Occasional Visitor
Posted: Wed Jun 08, 2005 11:33 pm Post subject: |
That did it.....many thanks |
LiveLifeGoJump Regular Visitor
Posted: Thu Jun 09, 2005 12:58 pm Post subject: |
Lorax wrote: |
I don't think you share a full postcode with different streets. That would make the use of postcodes pointless!! Maybe one street name has a postcode and then you just look for the house number (which the postcode addon doesn't seen to let you input).
Lorax |
A postcode is NOT split over 2 or more streets. One street MAY have more than one postcode.
ANY software using postcodes should find the property you are looking for on entering full postcode + house no. Where the properties are named and do not have a number assigned to them should be listed for selection.
If you require the correct address &/or posctcode this may be searched on www.Royalmail.com. You have to register (free) & it allows upto 12 searches per day.
Postman Norman (Pat and his black & white cat will pay for it if I get my hands on them, they have a lot to answer for!!!!!!!) _________________ If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE |
nej Frequent Visitor
Joined: Jun 16, 2004 Posts: 454 Location: London, Ingerlund
Posted: Thu Jun 09, 2005 1:45 pm Post subject: |
Is it me or does the postcode just get you to the road?
I frequently use the postcodes to visit places, and often they don't have house numbers (i.e. offices) , but the postcode is perfect. How would I choose the housenumber if I don't have one? The postcode should be good enough. |
proeliator2001 Occasional Visitor
Joined: 24/03/2003 18:35:49 Posts: 20 Location: United Kingdom
Posted: Thu Jun 09, 2005 1:51 pm Post subject: |
Cheers for that, my postcodes work fine now - just cancelled my question to TomTom |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Thu Jun 09, 2005 7:49 pm Post subject: |
yup cheers for the info mine is working a treat now as well _________________ TomTom 5001 |
lsuhe Occasional Visitor
Posted: Fri Jun 10, 2005 7:13 am Post subject: |
TuurG wrote: | Instead of using your pocketpc's memory, leave the ZIP folder on your SD card.
But add a folder TOMTOM to the SD card.
Why this would help? The app searches for a TomTom folder, and then searches for all other folders (VOICE, SCHEME, ZIP,...) alongside of this folder. That's why it works with the postalcodes file stored on the PocketPC; you have a TomTom folder with the activation code and settings on your device, in the root and/or in MyDocuments. |
What exactly do you mean. I got it to work by putting hte zip folder and the 2 fiels insiee it at the root level of the pocket pc. but do you copy the zip folder to inside the newly created tom tom folder
e.g.
\CF card\TomTom\Zip\postcode files
or
\CF Card\Tomtom\postcode files.
I am really confused about what exactly you are supposed to do as when I try this I can't get the 7 digits working. Can we have an idiots guide to sorting the postcodes out please?? !! (for me:)
Chris |
vlak Regular Visitor
Posted: Fri Jun 10, 2005 7:21 am Post subject: |
Isuhe,
Do the following on your Memory card (SD or CF):
/Memory card/zip/Great_Britain.postal
/Memory card/TomTom/
The TomTom folder is empty.
As Tuurg explained earlier, When launched, the Navigator application looks for a "TomTom" folder and then for any other related folders. |
radavis Regular Visitor
Joined: Mar 27, 2004 Posts: 132 Location: Woodford Green. Essex. UK
Posted: Fri Jun 10, 2005 1:48 pm Post subject: |
I have the same problem.
I even did a hard reset on my Ipaq and installed tt5 from scratch and I do not get the facilty to do a full UK postcode search. |
sh01 Occasional Visitor
Posted: Fri Jun 10, 2005 3:15 pm Post subject: |
I had the same problem with 7 digit post codes not working. Adding a tomtom folder to SD card sorted it out! Thank you! |
Posted: Fri Jun 10, 2005 4:18 pm Post subject: |
thanks, mines sorted now, postcodes on CF card.
Chris |
fergyuk Occasional Visitor
Posted: Fri Jun 10, 2005 5:22 pm Post subject: |
Please make this a sticky
Fergy |
steveky Occasional Visitor
Posted: Fri Jun 10, 2005 10:01 pm Post subject: postcodes |
I have done everything you say but still can't get the full postcodes, I didn't load the plus map though, could this be my problem?
Steve |
julianbarker Lifetime Member
Posted: Fri Jun 10, 2005 10:23 pm Post subject: |
No - Postcodes work as long as you have at least the basic version of the map, and the postcode files i nthe Zip folder. As wel las the map file i nthe root of the card, the Zip folder i nthe root of the card, yo ualso need a TomTom folder in the root of the card. As long as you have them it should work - it did for me when I got it set up like that. |
blackscooby Occasional Visitor
Posted: Fri Jun 10, 2005 11:33 pm Post subject: |
Folder called TomTom in root of the SD Card did it for me!
Some of the quirks are annoying already |
