Pocket GPS World :: View topic - Tomtom Nav 1,21 and ipaq3870! Help!!
hadrian5
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Tomtom Nav 1,21 and ipaq3870! Help!! Reply with quote
Help I am desperate. I have TTnav 1.21 and a compaq 1paq 3870. When I installed the program on to my PPC, I get the error" Cannot determine location of data. Please reinstall data and /or application". I have installed it normally and also after a hard reset.
The program is installed, but for some reason it cannot execute the program. When I go into file explorer it shows the folowing: Under my device is a folder called TomTom, which has 4 files in it. Then when I open program files there is a folder called Navigator, which seems to have the main program in it. However, when I click on the TT icon I sill get the error. I sent an email to Tom Tom, but I have not had a reply!. Can anyone help and come up with a solution. Maybe the guys at GPS can help.
Many thanks H
AndyF
This might sound like a silly question, but have you installed any maps for TTnav to use?
Andrew
As AndyF has said, that error simply means that you have not installed any maps. Install a map and all will be well again.
hadrian5
I have the GB maps on my SD storage card and the software in the main memory. Should the maps be elsewhere
That should be fine. How did you install the maps? Can you see a GB Folder on the storage card as TomTom doesn't seem to be able to find it?
nicknick
That wouldn't be a Sandisk SD card by any chance would it.
There seems to be some problems using SD cards which may involve the need to reformat with a different sector size (see here http://www.pocketgpsworld.com/forum/display_topic_threads.asp?ForumID=62&TopicID=2189&PagePosition=1).
Sometimes ejecting and then reseating the card (and then doing a soft reset) can make it work (temporarily) - this then does indicate an SD problem
Nick
nicknick
Although an upgrade to 1.52 might help (http://www.tomtom.com/support/ce/support/download_navigator.php)
Nick
hadrian5
Many thanks for all your comments. I have managed to get it working. I reinstalled everything on the main memory and the GB map on to the storage card. It all now works
adrian
22.053 (15 May 24)
