Pocket GPS World :: View topic - TomTom Go v5 Upgrade Available for Download
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Tomh26
PostPosted: Thu Apr 14, 2005 3:43 pm    Post subject: Reply with quote
all done :D cheers
Boblites
PostPosted: Thu Apr 14, 2005 4:54 pm    Post subject: Reply with quote
Hi everybody, hope you will welcome another dumb user who is having a problem trying to install V5 on a TTG.
I have downloaded the upgrade and after clicking on the setup.exe file the TomTom screen opens. I then follow the instructions but all the application wants to load is the Jane voice. Anyone know what I am doing wrong as this is driving me nuts and I am beginning to regret selling my Mio268 and buying a TomTom.
pawsey
PostPosted: Thu Apr 14, 2005 5:43 pm    Post subject: Reply with quote
Just a thought
Did the file you downloaded have the filename: ttgoupg500.exe ? This is the upgrade setup file...
If the file you downloaded has the filename setup.exe, then that is possibly the wrong file. The upgrade file is 5,570KB in size.
Markie
PostPosted: Thu Apr 14, 2005 6:14 pm    Post subject: Reply with quote
Have you tried loading / removing different voices in from the original cd that came with the go?
Tomh26
PostPosted: Thu Apr 14, 2005 7:44 pm    Post subject: Reply with quote
guys all the new features seem to have added fine, but the postcodes are still doing the same ?? EG its only letting me do w13 6 and then wont let me add anymore ! all the new options are there like it says on the page Embarassed
squigles
PostPosted: Thu Apr 14, 2005 7:56 pm    Post subject: Reply with quote
That's because v5 is not a full update, if you want to have FULL POSTCODE SEARCH & CONGESTION CHARGE/TOLL ROADS then you have to wait until May when you have to buy the map udates for most of the new functions in v5 to work 8O
View user's profile Send private message Send e-mail AIM Address
kk
PostPosted: Thu Apr 14, 2005 7:57 pm    Post subject: Reply with quote
Quick question before I attept the upgrade...is the map activation code the 10 digit number printed on the sd card case i.e. 2XXX.XXX.XXX
squigles
PostPosted: Thu Apr 14, 2005 8:01 pm    Post subject: Reply with quote
That's it kk :D
Tomh26
PostPosted: Thu Apr 14, 2005 8:41 pm    Post subject: Reply with quote
thank you very much sir :D
Boblites
PostPosted: Thu Apr 14, 2005 8:44 pm    Post subject: Reply with quote
Hi pawsey,
Thanks for your reply. Yes the file had the name ttgoupg500.exe. I unzipped this file and then clicked the setup.exe and the result was it loaded Janes voice and nothing else. I have deleted the download file 3 times and re-downloaded it in case there had been an error but it still did the same thing.
I have done as Markie has suggested and used my original CD to load/delete voices and this worked OK and saved me space on the SD card, which is the original 128 Mb TomTom card version 4.2 which has only got a camera database added.
So I am still open to any further suggestions, but be polite please.
JackieHigh
PostPosted: Fri Apr 15, 2005 1:40 am    Post subject: Reply with quote
Hi Boblites
I also had this problem but found that when i removed the original CD from the drive and then double clicked the downloaded file it worked fine. Hope this helps.
Jackie Smile
Boblites
PostPosted: Fri Apr 15, 2005 12:53 pm    Post subject: Reply with quote
Thanks a lot to keefy and JackieHigh, did as you suggested and removed CD from drive and Hey Presto installed with no problem.
Once again many thanks to all who have taken the time to help me sort the problem and I'm sure this will help others.
spacerunner
PostPosted: Sun Apr 17, 2005 2:02 pm    Post subject: TTG Ver 5:00 Reply with quote
I downloaded and installed the upgrade with no probs at all. I am very impressed with the 'Itinery' feature as it was the only serious niggle i had with ver 4:40. However I have noticed that since the upgrade TTG has taken longer to pick up sattelite connection. Anybody else noticed this?
gingernut777
PostPosted: Mon Apr 18, 2005 6:46 am    Post subject: Re: TTG Ver 5:00 Reply with quote
No difference with mine.
Using an A to Z
Sextant & Compass
PostPosted: Mon Apr 18, 2005 7:43 am    Post subject: Reply with quote
Mines the same as before.
Page 3 of 7
