Pocket GPS World :: View topic - Poi Warnings - TTGo910
Fraserp
PostPosted: Fri Aug 04, 2006 7:38 am    Post subject: Poi Warnings - TTGo910 Reply with quote
I've a TTG910 App: 6.110. Does anyone have any ideas why do I get POI warnings when the POI's are not on the route I am travelling?
This has occurred where the POI's are nearby the route i am on, for say traffic light camer and speed cameras. I have edited the 'Warn when near POI' option to 'only on route' but I still get the warnings.
It's not life threatening, just annoying.
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
PostPosted: Fri Aug 04, 2006 8:22 am    Post subject: Reply with quote
Mine does this, I have found that usually when this occurs the camera (or other POI for that matter) is close to the actual route you are on so the device issues the alert, it doesn't happen all the time, but where it does occur it allways issues a warning when passing the same location (M6 south bound near the large Argos depo, the junction around here I always get a Gatso warning on the motorway - Its on an adjacent road) - Mike
Fraserp
PostPosted: Fri Aug 04, 2006 10:12 pm    Post subject: Reply with quote
So... when edited the 'Warn when near POI' option to 'only on route' doesnt actually work?
Instead if a POI appears and it's within a 'certain' distance to the route it is activated.
Hmm.....
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
PostPosted: Fri Aug 04, 2006 10:22 pm    Post subject: Reply with quote
It does exactly the same thing when you run TTN5,21 on a PDA, the same alerts for the same camera positions, so I guess its consistant, I don't find that there are too many camera positions that do this, there are probably four or five that spring to mind, and I do cover quite a distance with the nav units each week - Mike
PostPosted: Fri Aug 11, 2006 2:43 am    Post subject: Reply with quote
I'm sure this happens more than it used to with earlier software versions.
Now I often find that at motorway junctions, the slip road and any roundabout etc. seem to be included in the "route", so any cameras on the roundabout trigger an alert as you sail past on the main road. Sad
I'm convinced that when I first started playing with "Warn only when on route", it stopped all of those false alerts.
JockTamsonsBairn
PostPosted: Fri Aug 11, 2006 12:31 pm    Post subject: Reply with quote
It sounds like the software has been "improved" to that cameras located on over bridges will trigger an alert. Can anyone confirm?
Jock
22.044 (24 Apr 24)
