Pocket GPS World :: View topic - ins sleeve and tt2.02 not working
gregh
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: ins sleeve and tt2.02 not working Reply with quote
Hi there,
I've been using ins for some time and have just upgraded to TomTom v2, however TomTom doesn't appear to see my sleeve. This is on a 5450 and a 3630.
I've installed the latest navman serial drivers, v 3-1-6, and also the latest TomTom upgrades.
If I choose the GPS icon that TomTom installed then I'm choosing TomTom Navigator GPS and serial cable on COM6: I've got the tickbox next to this selected and the small pocketpc slider over to the right so the mini tomtom logo is displayed.
If I then go to the Status screen everything is grey - am I correct in assuming at least the satellite->Tomtom logo should be animated whilst it tries to lockon?
From searching around this very useful site I downloaded Winfast navigator, set it to Com6 57600k and click connect and nothing happens, just a screen with navigation messages view.
Help!
Greg
Greg, make sure you're using the TomTom Navigator GPS Sleeve option, and the COM port that your sleeve normally talks on. It's usually something like COM5-8 depending on what else you have installed that has COM ports assigned. If you select this driver, and tick the tick box, you should then be able to goto the GPS Status screen and this will start showing some gray sat bars.
There were problems with the iNS not working, and a driver was required to get it working with other software like TTN2, and I'm not sure, but I think it was the Navman Serial Drivers so I believe you should be okay.
gregh
if i choose
TomTom GPS (IPAQ sleeve)
then the only option I see is GPS receiver
if I choose
I get these options:
serial cable on COM0
COM3:
Serial cable on COM6
USB cable@
bluetooth serial port COM5
bluetooth serial port COM8
which I then choose COM6 but I still get nothing Sad
Greg
If you eject the sleeve and put it back onto the iPAQ, do you get an "Unrecognised Card" error ? If you are seeing this, then check out this thread as another Compaq iNS user had this problem.
TBH I've never seen it listed as Serial cable on COM6.   Usually when you select the TomTom GPS Sleeve you get another option (the exact title escapes me), but it's something like GPS Sleeve.
gregh
I do indeed get the unrecognised card error, so will try following that thread.
If I uninstall TT2 in order to install the Navman sware indicated in that thread, do I need to re-activate TT? I've already activated it twice Sad
Greg
gregh
latest is when I try and install the Navman upgrade I get a optscanbus error message.
it says: OptScanBus Failed!
and that's all.
This is proving nice and easy isn't it!!!!!
Greg
NickR
Greg
Works fine on my setup
iPAQ 3970 and Compaq iNS.
I use the TomTom GPS (iPAQ Sleeve) on COM6.
Nick
Gre, I think you'll need to contact NAvman. It sounds like you don't have the underlying driver that supports the OptScanBus. I thought it was contained within the Serial Driver, but maybe it's not.
gregh
Nick,
can you tell me what you did/installed to get this working!!! I've tried it on a 3630 and 5450 with no luck :^(
Greg
gregh
I've re-installed INS and all appears fine, with this installed the Navman GPSInfo tool runs fine.
So somehow I need to keep the driver parts of INS and blow the rest away!!
regards,
greg
NickR
Greg
I guess that is why I did not have a problem because I left the original ins drivers and software on the pda.
Did you have trouble with the cf card not been recognised after you uninstalled to pocket co-pilot?? (I had to reset the ipaq back to defaults to get the cf card back?)
Nick
gregh
Yup, got card not recognised message when you attach the sleeve, even if there is no card inserted!
So I've left Pocket CoPilot installed, removed CoPilot speech and also LiveWire and re-installed TomTom v2,and lo and behold it looks like its working.
Greg
Excellent, good to see you're sorted now!
22.062 (12 Jun 24)
