Gazza44 Occasional Visitor
Posted: Fri Mar 18, 2005 10:41 am Post subject: Couple of easy ones!!! |
Hi all,
Hope you can help with a couple of questions;
1) Is there any way that when I go to Map View that it will go to where I am rather than having to start on 0-500 mile scale and scour the country for the Blue arrow? (The circle with the cross in seems to please itself where it turns up).
2) Is there a way of re-arranging the order of my Favourites. I'd rather put my most frequently used ones near the top or be allowed to shuffle the pack etc or do i have to re-visit them all and re-assign?
Garry |
Darren Frequent Visitor
Posted: Fri Mar 18, 2005 10:49 am Post subject: |
In Properties enable the 'Keep GPS Position On Screen' or something like that option! That will launch Map View with your current position centered.
If I recall correctly, the favourites can be re-ordered. Switch to Favourites View and do it from here. _________________ Darren Griffin |
barryd Frequent Visitor
Joined: Mar 27, 2004 Posts: 285 Location: Cheshire, England
Posted: Fri Mar 18, 2005 10:55 am Post subject: |
Darren wrote: | In Properties enable the 'Keep GPS Position On Screen' or something like that option! That will launch Map View with your current position centered. |
That will keep the map snapped to your current position whenever you have a GPS fix - if you try to move the map around it'll keep snapping back.
If you just want to jump to your current position then be able to move the map around, leave that option turned off and simply tap the GPS fix symbol (a set of bars and a number) at the top right of the screen to jump to your position. _________________ Barry Davies
Posted: Fri Mar 18, 2005 10:59 am Post subject: |
Thanks Barry, that is a much better solution! _________________ Darren Griffin |
Posted: Fri Mar 18, 2005 8:31 pm Post subject: |
Thanks Darren & barryd
Great tip on the GPS positioning..........still can't manage to re-arrange Favorites.....can't even find Favorites View.......sorry but stiil not familiar with system.
Thanks again
Garry |
Posted: Fri Mar 18, 2005 11:30 pm Post subject: |
Gazza44 wrote: | ...still can't manage to re-arrange Favorites.....can't even find Favorites View... |
It's an option on the top-left menu, same as where you switch between Map and Navigator views, etc. Select Favourites to see a scrollable list of your Favourites. Tap & hold on the one you want to change, then select Edit... on the menu that pops up. You can now change its name, description, and location in the list. _________________ Barry Davies
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Sat Mar 19, 2005 1:58 am Post subject: |
Take a tip from me and don't bother with Favourites apart from Home. Set up a group of POIs (you can even call them "favourites"- that way you will not loose them when eventually your system crashes. POIs are stored on the memory card.
Steve |
Posted: Sat Mar 19, 2005 1:58 pm Post subject: |
Thanks again Barry...........Steve, sure you're right just sounds a bit tricky. Rememeber this is a guy who couldn't even find Favorites View.
Thanks again
Garry |
Posted: Sun Mar 20, 2005 2:01 am Post subject: |
When in Map view, just keep stylus on location, and then choose "Add as point of interest" In type box choose <New type> and overtype with whatever you want to call them. Easy then to add more to that category. It will initially show as a Black asterisk in a yellow box, but you can change the icon when you get a bit more experience.
Steve |
Posted: Tue Mar 22, 2005 8:13 pm Post subject: |
Thanks Steve
I'll have a go......Once again you only find out about these things when you want to try and fine tune something or by reading forums
Garry |
