markqbase Occasional Visitor
Posted: Sat Jan 22, 2005 5:20 pm Post subject: XDA II & Navman 4420 GPS bluetooth problem |
I have just bought a Navman 4420 for pocket PC. I am running ROM version 1.72.00WWE, radio version 1.17.00 on an XDA II. I think I can bond the XDA with my GPS ONE receiver, (it has accepted NAVMAN passkey, once I installed the patch) but I am not clear on how to set up the COM port. The bluetooth light on the GPS continues to double flash, suggesting it has not bonded. please help!! |
alix776 Pocket GPS Moderator
Posted: Sat Jan 22, 2005 5:36 pm Post subject: |
youll need to set the com port as com 5 in not sure of the baud rate try 3400 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Jan 22, 2005 5:46 pm Post subject: |
how do i set the port though? instructions say to use the GPS Status screen on PDA, bur software won't let me as it brings up the "waiting for gps" message, and no menus! |
Posted: Sat Jan 22, 2005 5:56 pm Post subject: |
im not familiar with the navman sofctware though if you hang on a while one of the others should be able to help _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jan 22, 2005 6:45 pm Post subject: problem solved |
The instruction manual is wrong - it states that the BT will flash once to show it's paired, then go on to set up the COM port on the app & do a GPS fix. It actually double flashes, then set up the port and it single flashes, then do a fix! Confused? I have been all day! |
Posted: Sat Jan 22, 2005 8:10 pm Post subject: |
as its a new reciver try leaveing it on with a clear veiw of the sky say in the car or on a window sill (thought doubleglazing is heatreflective glass)
for around 30-45 minutes switch on then try and pair it again when pairing it you will be asked if you want to create a serial port at this point select yes. ifyou still have no look then download pocket bluetooth tools from the link and try the process againhttp://www.bluetooth.jazztel.es/ _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Jan 23, 2005 6:41 pm Post subject: |
thanks for your help! all worked fine once I sussed that the instructions were in the wrong order! |
