Orli Occasional Visitor
Posted: Wed Jan 19, 2005 10:59 am Post subject: NAVMAN GPS 3400 and Navigon 4 Softwar? |
Hi Folks
I'm from Switzerland (Bern) and new in the "GPS-Business". So my questions may be a bit silly but an short answer would help me.
I get from a friend a Navman 3400 (hardware only) for my Ipaq 3870 Pocket PC. I bougt now the Navigator 4 Softwar from Navigon and I installed it. But, my Pocket PC does not reconised the GPS cradel. It comes first with " Card unknown pleas enter first the Name of the Equipment!
Question? Do I need software to install for the NAVMAN and when "YES" is there any short version to install the driver only? The back color of sat-icon is always red.
Many thank in advanced!
Regards Orlando |
Posted: Wed Jan 19, 2005 12:14 pm Post subject: |
You probably need to install this driver. Download it to your PC and run it from there after unzipping it, ensuring your iPAQ is connected using Activesync. _________________ Tim |
Posted: Thu Jan 20, 2005 8:23 am Post subject: NAVMAN and NAVIGON ç |
Hello Tim
Many thanks for your fast replay.
I was installing the driver and it was looking very good till the end, my iPAQ pops up a setup window with the message: FAILED TO LOAD OPT PACK BUS DRIVER!!
And I still was not able to run the NAVMAN with the NAVIGON together.
Any more Ideas are appreciated.
Best Regards
Orlando |
Posted: Thu Jan 20, 2005 11:59 am Post subject: |
Remove the sleeve from the iPAQ, soft reset the iPAQ and try to install the driver again. Then soft reset again and plug it all back together. _________________ Tim |
Posted: Fri Jan 21, 2005 9:29 am Post subject: |
Hello Tim,
Great news! Following your instructions, the driver is now properly installed. On the NAVIGON setup, in the GPS section, I selected now Receiver Typ “other receiver”, Com-Port “COM6: NavMan Driver” and the Baud rate ” 4800” to be on the save side.
I saved the setup, switched the iPAQ off an on again and did a soft reset. Starting the NAVIGON Software…….nothing happen, no GPS Signal and when I press on the Sat icon it tells me “No GPS-receiver was found, pleas check power and cables and the setup of the GPS configuration”!
Should I uninstall the Navigon 4 and reinstall it? I was also contacting the Help(less) desk at Navigon and they just told I have to check if the NAVMAN support the VTG or GGA protocol. But since I get the sleeve from a friend, I do not have any manuals and I can’t find on the NAVMAN homepage. Is this a problem with the protocol?
I was contacting the support of NAVMAN already two weeks ago and asking about Software (even if you are willing to pay some amount for the software)…. I think is worth it to tell you what I think of this “SUPPORT”.
Any other suggestion what I could do?
Sincerely
Orlando
PS: I’m outing myself as a softbiker (BMW K1200LT) |
r4zv4n Occasional Visitor
Posted: Sun Mar 27, 2005 9:58 am Post subject: |
I have the same issue with Ipaq 5450, Navman 3450 and Navigon 4
I have read somewhere that Navigon 4 requires a modified .ini file in order to work with Navman, but I do not have any further knowlege.
If somebody has the solution, please help |
