milesr3 Occasional Visitor
Posted: Fri Nov 05, 2004 11:05 am Post subject: Single OV2 file? |
Is it possible to get the database as a single OV2 file? I would like to convert it to GNS format for travel-i, which can only load a single file.
Thanks. |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Fri Nov 05, 2004 11:31 am Post subject: |
The current database was split as not everyone wanted the red light cameras or continental cameras included.
If you want a combined file it would be easier for you to merge them yourself.
Simply open each file in Notepad, cut one set of data and paste to the foot of the other to create one new file. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Fri Nov 05, 2004 11:33 am Post subject: |
Thanks!
I've been looking at the contents of the file with text and hex editors and was wondering whether this would be possible... |
Posted: Fri Nov 05, 2004 11:37 am Post subject: |
Oh what I wouldn't give to edit........
You will need to download the .csv files first as it would be easier. Then open each of them in Notepad, cut from one and paste to the other but make sure you leave out the 'Longitude,Latitude,Name' bit from the copied data. THEN convert the new file to .ov2 format.
Sorry about that! _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Fri Nov 05, 2004 1:40 pm Post subject: |
The best way that I have found to combine such files is to import the ones you want into Autoroute. When you have all the files you want, save the file as an .axe and then convert it to .csv or .ov2 (or any other supported format) using Oldie's POIConverter. _________________ Tim |
Posted: Fri Nov 05, 2004 4:40 pm Post subject: |
Thanks again for the help.
Oldie's POI converter has a very handy append function in it for doing exactly this with OV2 files without the need to start copy-pasting csvs and then converting (which also works). Thanks Oldie!
Doing a copy-paste in notepad and also a command line copy filea /B + fileb /B filec seem to produce the desired result too.
Richard Miles |
tomjeffs Occasional Visitor
Joined: 15/05/2003 15:17:39 Posts: 34 Location: United Kingdom
Posted: Sun Nov 07, 2004 6:01 pm Post subject: |
Would it also be possible to change the default ov2 filenames into something like pgps-gatso, because it sometimes doesn't fit on my display with checkpoint 3.2? |
AndyT Occasional Visitor
Posted: Fri Jan 14, 2005 1:17 am Post subject: GNS Convertors |
Hi Guys,
Did you know that Travel-iSolo (aka Travel-iPro) has a rather good convertor for various different files. Also Does file merges, sorting and Duplicate removal and will put the Files back on the PDA too !
You can also import/export CSV files of Lat/Long label.
Regards
Andy T |
