vkl Occasional Visitor
Posted: Mon Mar 04, 2019 9:59 am Post subject: |
Thanks Kremmen. I only have the gpx file called pocketgps_uk_sc.gpx in the PersonalPOI folder so I guess identically naming a WAV file won't work for me.
Thanks for your time though !! |
Kremmen Pocket GPS Verifier
Posted: Mon Mar 04, 2019 10:03 am Post subject: |
Are you sure your unit won't read a GPI file ? _________________ DashCam:
Viofo A119 V3 |
Posted: Tue Mar 05, 2019 10:02 am Post subject: |
Sadly, yes I have tried and it doesn't work with a .gpi file. |
treversuhenly Occasional Visitor
Posted: Sun Nov 10, 2019 4:31 pm Post subject: How to switch off audio warning for mercedes comardo sat nav |
Hi, I have recently installed pocketguide GPS speed camera warning in my E-Class Mercedes comardo sat nav. It works great but I can't switch off the audio warning which it beeps every single time when I go past a speed camera.
I try to switch off the audio and visual warning but the system resets it straightaway. So it won't let me switch off the audio warning. If anyone knows how to switch off the audio warning and without resetting it but still keep the speed camera signs on that will be great.
Thank you in advance,
Trevor |
Posted: Sun Nov 10, 2019 5:10 pm Post subject: |
Are you having to use Garmin POILoader ?
If so then you'll need to use SOX.exe and use some empty WAV files.
I won't go any further until I know about POILoader. _________________ DashCam:
Viofo A119 V3 |
M8TJT The Other Tired Old Man
Posted: Sun Nov 10, 2019 9:54 pm Post subject: |
Why on earth would you not want audio warnings? |
Posted: Mon Nov 11, 2019 5:41 am Post subject: |
I think it's the annoying beep that isn't required. I'd probably want the same given that modern cars beep for all manner of things.
I was going to expand on the verbal warnings in step 2 _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Nov 11, 2019 10:34 am Post subject: |
Ah. There you go then. I see. Now let me get this straight. 'No sound' really means 'different sound'? |
Posted: Mon Nov 11, 2019 10:56 am Post subject: |
Kremmen wrote: | Are you having to use Garmin POILoader ?
I won't go any further until I know about POILoader. |
No I use comard sat nav not Garmin POILOader. |
Nemesis1 Regular Visitor
Posted: Sun Dec 29, 2019 2:16 am Post subject: |
Good evening.
It’s been a while.......
So in the end I stopped fighting the audio 20 and accepted its limits. I was bought a Garmin dash cam for Xmas a few years ago and it’s really rather good when you delete the Cyclops database and load the PGPSW one instead.
Anyway......
It’s car change time for me, and my new Merc arrives in March, this time with command. So I’m keen to see if it will work this time?
Posted: Sun Dec 29, 2019 5:47 am Post subject: |
Keep us posted.
Due to an ongoing move I'm not as active on my PC of late but I'll endeavour to make any changes required. _________________ DashCam:
Viofo A119 V3 |
DaveKiwi Occasional Visitor
Posted: Tue Jan 28, 2020 9:53 am Post subject: Hi Will this work with Windows 10 laptop, thats all i have a |
Hi Will this work with Windows 10 lap top, thats all i have access to? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Tue Jan 28, 2020 11:06 am Post subject: Re: Hi Will this work with Windows 10 laptop, thats all i ha |
DaveKiwi wrote: | Hi Will this work with Windows 10 lap top, thats all i have access to? |
Do you mean can you run a speed camera warning database on a laptop? Not sure but I think having a laptop running while you're driving may have some safety issues attached... |
Posted: Tue Jan 28, 2020 12:06 pm Post subject: Re: Hi Will this work with Windows 10 laptop, thats all i ha |
MaFt wrote: | DaveKiwi wrote: | Hi Will this work with Windows 10 lap top, thats all i have access to? |
No, the instructions reference using laptop driven by Xp / Windows 7 to download the database to and to compile the SD card.
i just want to know is the process / software compatible with Windows 10 |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 755 Location: Knaresborough, North Yorkshire.
Posted: Tue Jan 28, 2020 1:11 pm Post subject: |
Yes, the procedure is just the same under Windows 10. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
