Pocket GPS World :: View topic - Mercedes Comand Online ntg4.5 - Personal POI data support
Goto page Previous  1, 2, 3 ... , 14, 15, 16  Next
vkl
PostPosted: Mon Mar 04, 2019 9:59 am    Post subject: Reply with quote
Thanks Kremmen. I only have the gpx file called pocketgps_uk_sc.gpx in the PersonalPOI folder so I guess identically naming a WAV file won't work for me.
Thanks for your time though !!
PostPosted: Mon Mar 04, 2019 10:03 am    Post subject: Reply with quote
Are you sure your unit won't read a GPI file ?
Satnav:
Car Average MPG :
vkl
PostPosted: Tue Mar 05, 2019 10:02 am    Post subject: Reply with quote
Sadly, yes I have tried and it doesn't work with a .gpi file.
treversuhenly
PostPosted: Sun Nov 10, 2019 4:31 pm    Post subject: How to switch off audio warning for mercedes comardo sat nav Reply with quote
Hi, I have recently installed pocketguide GPS speed camera warning in my E-Class Mercedes comardo sat nav. It works great but I can't switch off the audio warning which it beeps every single time when I go past a speed camera.
I try to switch off the audio and visual warning but the system resets it straightaway. So it won't let me switch off the audio warning. If anyone knows how to switch off the audio warning and without resetting it but still keep the speed camera signs on that will be great.
Thank you in advance,
Trevor
PostPosted: Sun Nov 10, 2019 5:10 pm    Post subject: Reply with quote
Are you having to use Garmin POILoader ?
If so then you'll need to use SOX.exe and use some empty WAV files.
I won't go any further until I know about POILoader.
Satnav:
Car Average MPG :
PostPosted: Sun Nov 10, 2019 9:54 pm    Post subject: Reply with quote
Why on earth would you not want audio warnings?
PostPosted: Mon Nov 11, 2019 5:41 am    Post subject: Reply with quote
I think it's the annoying beep that isn't required. I'd probably want the same given that modern cars beep for all manner of things.
I was going to expand on the verbal warnings in step 2
Satnav:
Car Average MPG :
PostPosted: Mon Nov 11, 2019 10:34 am    Post subject: Reply with quote
Ah. There you go then. I see. Now let me get this straight. 'No sound' really means 'different sound'?
treversuhenly
PostPosted: Mon Nov 11, 2019 10:56 am    Post subject: Reply with quote
No I use comard sat nav not Garmin POILOader.
Nemesis1
PostPosted: Sun Dec 29, 2019 2:16 am    Post subject: Reply with quote
Good evening.
It’s been a while.......
So in the end I stopped fighting the audio 20 and accepted its limits. I was bought a Garmin dash cam for Xmas a few years ago and it’s really rather good when you delete the Cyclops database and load the PGPSW one instead.
Anyway......
It’s car change time for me, and my new Merc arrives in March, this time with command. So I’m keen to see if it will work this time?
PostPosted: Sun Dec 29, 2019 5:47 am    Post subject: Reply with quote
Keep us posted.
Due to an ongoing move I'm not as active on my PC of late but I'll endeavour to make any changes required.
Satnav:
Car Average MPG :
DaveKiwi
PostPosted: Tue Jan 28, 2020 9:53 am    Post subject: Hi Will this work with Windows 10 laptop, thats all i have a Reply with quote
Hi Will this work with Windows 10 lap top, thats all i have access to?
PostPosted: Tue Jan 28, 2020 11:06 am    Post subject: Re: Hi Will this work with Windows 10 laptop, thats all i ha Reply with quote
Do you mean can you run a speed camera warning database on a laptop? Not sure but I think having a laptop running while you're driving may have some safety issues attached...
DaveKiwi
PostPosted: Tue Jan 28, 2020 12:06 pm    Post subject: Re: Hi Will this work with Windows 10 laptop, thats all i ha Reply with quote
No, the instructions reference using laptop driven by Xp / Windows 7 to download the database to and to compile the SD card.
i just want to know is the process / software compatible with Windows 10
dales
PostPosted: Tue Jan 28, 2020 1:11 pm    Post subject: Reply with quote
Yes, the procedure is just the same under Windows 10.
Page 15 of 16
22.034 (27 Mar 24)
