markyd Occasional Visitor
Posted: Fri Oct 08, 2004 7:27 am Post subject: Download the Trine datalog |
I've got a new Emtac Trine, and after some teething troubles with my H3970 and PPC2003 everything is working fine. Really impressed with the Trine!
The thing I am struggling with is the datalogger. How do I download its contents? There are a couple of utilities that came with it on CD but they are basic at best and have no instructions.
Is the datalogger turned ON by default? If so how do I down load the log?
I have a BT USB dongle on the PC so I'm trying to download straight to that, not the PPC.
Is there any other software that will work?
Mark |
ajdelore Occasional Visitor
Posted: Tue Oct 12, 2004 7:19 pm Post subject: Trine Datalogger |
The datalogger is not enabled by default. You need to turn it on and view it using their software. You can also set all the parameters -- do you want it to log when position changes by x metres, or after every x seconds, for example. The software is a bit cryptic, but if you work with it you can figure it out.
Unfortunately, there is no Palm (or PocketPC) application. I have used BT Serial Pro to connect to the datalogger from my palm. You could issue commands through this program, and then dump the output to the screen and cut-n-paste it into a memo. Clumsy, but workable.
Anthony |
pwwuk Occasional Visitor
Joined: 26/04/2003 06:59:41 Posts: 8 Location: United Kingdom
Posted: Fri Jan 14, 2005 8:33 am Post subject: |
ll I get is a BIN file with the CRUX_LOG SW .. >> ?? Help ?? |
SJ Occasional Visitor
Posted: Thu Mar 24, 2005 6:27 pm Post subject: |
I've just received my Trine and in the same position. Has anyone worked what to do with the BIN file?
SJ |
adamschneider Occasional Visitor
Posted: Wed May 04, 2005 10:59 pm Post subject: |
GPS Visualizer can now read the .bin files from the CRUX_LOG program: http://www.gpsvisualizer.com/
Let me know if you have any problems. |
Posted: Thu May 05, 2005 12:33 am Post subject: |
That is because you are a god ! :P
Thank you so much for un wrapping the puzzle..
I know it took many hours to write the importer ..
Let me be the first to say thank you !!
Peter |
Posted: Sun May 08, 2005 3:19 pm Post subject: |
Thanks from me too. Works like a treat Trine -> GPX -> Memory-Map.
Cheers,
SJ |
