Paul600 Occasional Visitor
Posted: Sun Mar 17, 2019 5:14 pm Post subject: Hand held GPS for marking waypoints when fishing . |
Hi , I'm a total novice in the world of gps and all that goes with it and hope I've.posted in the correct forum .
I'm a fresh water fisherman that fishes very large gravel pits , I use a boat to place my baits in very specific areas of a couple of square meters up to 200 yards out in the lake , I use these areas throughout the year . I am thinking of getting a gps to mark the areas , which would be so much easier at night .
So my question is simply which unit would you recommend . I know I'm not going to be pin point accurate but with 3 or 4 meters would be perfect .
Many thanks for your advice in advance . |
sussamb Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sun Mar 17, 2019 5:45 pm Post subject: |
If that's all you need, no mapping, then a simple GPS like the Etrex 10 would do. Alternatively you could download a mapping program like ViewRanger to your smartphone and use that. _________________ Where there's a will ... there's a way. |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Sun Mar 17, 2019 6:55 pm Post subject: |
Normally I'd say use a cheap smartphone and app. However, as you're wanting to use it on the water I'd go for a GPS Receiver.
However, I'd check whether the Etrex 10 is: waterproof; can float; can be tied to a lanyard; preferably can be backed up to a computer. So if you were unfortunate to lose it you could get another one and reprogram it with your fishing locations.
Garmin Camper 770 LMT-D |
Posted: Sun Mar 17, 2019 7:29 pm Post subject: |
sussamb wrote: | If that's all you need, no mapping, then a simple GPS like the Etrex 10 would do. Alternatively you could download a mapping program like ViewRanger to your smartphone and use that. |
Thank you for your reply , from what I can gather 3 or 4 m is as good as I can expect unless I go for a very expensive one ? |
Posted: Sun Mar 17, 2019 9:32 pm Post subject: |
Yes, consumer grade devices can't get much better than that. _________________ Where there's a will ... there's a way. |
Posted: Sun Mar 17, 2019 9:35 pm Post subject: |
Privateer wrote: | Normally I'd say use a cheap smartphone and app. However, as you're wanting to use it on the water I'd go for a GPS Receiver.
Regards, |
Both can be placed in waterproof pouches if necessary, although the Etrex is waterproof to IPX7. Both can have their data transferred to PC etc. _________________ Where there's a will ... there's a way. |
Posted: Sun Mar 17, 2019 10:29 pm Post subject: |
sussamb wrote: | Privateer wrote: | Normally I'd say use a cheap smartphone and app. However, as you're wanting to use it on the water I'd go for a GPS Receiver.
Regards, |
Both can be placed in waterproof pouches if necessary, although the Etrex is waterproof to IPX7. Both can have their data transferred to PC etc. |
Great thank you very much for your help . |
