keenrw Occasional Visitor
Posted: Fri Jan 24, 2014 9:00 pm Post subject: Add on lighter socket causes loss of Digital traffic |
When plugged into the lighter socket on its own my 2598 can pick up digital traffic with out problems but when I add a three way lighter socket so I can use my dash cam and digital radio .. it reverts to the smart phone link traffic and has trouble connecting to the digital traffic , is this normal ?
Rich |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri Jan 24, 2014 11:17 pm Post subject: |
No idea as I don't use a 3 way socket, guess it's not getting enough power so not 'seeing' the power cable/antenna |
Kremmen Pocket GPS Verifier
Posted: Sat Jan 25, 2014 6:44 am Post subject: |
Presumably if you unplug the other devices whilst 'live' it gives more power and suddenly jumps into life ? _________________ Satnav:
Car Average MPG :
Allan_whoops Frequent Visitor
Posted: Sat Jan 25, 2014 9:47 am Post subject: |
Given my experiences of using both digital traffic and smartlink (freezes, crashes etc.) this is probably a good thing! |
GerryC Pocket GPS Moderator
Posted: Sat Jan 25, 2014 12:28 pm Post subject: |
It may be that it's using the power cable as an antenna and the electronics in the three way is stopping the signal coming through. I don't know the system so this is just speculation.
Gerry |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Sat Jan 25, 2014 1:05 pm Post subject: Diagnostics |
keenrw wrote: |
when I add a three way lighter socket so I can use my dash cam and digital radio .. it reverts to the smart phone link traffic |
Assuming it's just a 'dumb' socket, I would speculate that it's either: voltage-drop caused by the load of the other two devices, or maybe RF interference? (I would have thought the second option much more likely than the first, unless it's really poorly made).
I'm not familiar with the 2598 specifically, but all the Nüvi's I've seen to date have diagnostics that might help. Usually, there's a set accessed by holding the "Speedo" on the dashboard screen that shows you received Traffic Services etc. If you hold the "Time" (or the battery symbol) on the main screen for about 7 seconds, there's another set of diagnostics - the 1st page of which shows the power supply voltage. Accessing this set of diags. will probably cause the GPS receiver to do a 'cold-start' when rebooted.
You might have to hunt around to find them - but I've seen 'em on everything from the Streetpilot C510 to the latest 3598LMT-D.
