Pocket GPS World :: View topic - Add on lighter socket causes loss of Digital traffic
keenrw
PostPosted: Fri Jan 24, 2014 9:00 pm    Post subject: Add on lighter socket causes loss of Digital traffic Reply with quote
When plugged into the lighter socket on its own my 2598 can pick up digital traffic with out problems but when I add a three way lighter socket so I can use my dash cam and digital radio .. it reverts to the smart phone link traffic and has trouble connecting to the digital traffic , is this normal ?
Rich
PostPosted: Fri Jan 24, 2014 11:17 pm    Post subject: Reply with quote
No idea as I don't use a 3 way socket, guess it's not getting enough power so not 'seeing' the power cable/antenna Confused
PostPosted: Sat Jan 25, 2014 6:44 am    Post subject: Reply with quote
Presumably if you unplug the other devices whilst 'live' it gives more power and suddenly jumps into life ?
Satnav:
Car Average MPG :
Allan_whoops
PostPosted: Sat Jan 25, 2014 9:47 am    Post subject: Reply with quote
Given my experiences of using both digital traffic and smartlink (freezes, crashes etc.) this is probably a good thing! Very Happy
GerryC
PostPosted: Sat Jan 25, 2014 12:28 pm    Post subject: Reply with quote
It may be that it's using the power cable as an antenna and the electronics in the three way is stopping the signal coming through. I don't know the system so this is just speculation. Confused
Gerry
PhilHornby
PostPosted: Sat Jan 25, 2014 1:05 pm    Post subject: Diagnostics Reply with quote
Assuming it's just a 'dumb' socket, I would speculate that it's either: voltage-drop caused by the load of the other two devices, or maybe RF interference? (I would have thought the second option much more likely than the first, unless it's really poorly made).
I'm not familiar with the 2598 specifically, but all the Nüvi's I've seen to date have diagnostics that might help. Usually, there's a set accessed by holding the "Speedo" on the dashboard screen that shows you received Traffic Services etc. If you hold the "Time" (or the battery symbol) on the main screen for about 7 seconds, there's another set of diagnostics - the 1st page of which shows the power supply voltage. Accessing this set of diags. will probably cause the GPS receiver to do a 'cold-start' when rebooted.
You might have to hunt around to find them - but I've seen 'em on everything from the Streetpilot C510 to the latest 3598LMT-D.
22.043 (17 Apr 24)
