Adamantium Occasional Visitor
Posted: Thu Dec 26, 2013 2:10 pm Post subject: Feature request |
This might be little used but I hope it can be do e.
I leave a dedicated old iPhone in my car all. The time, just for the purposes of running cameralert directly through my audio system. The iPhone doubles as my music source.
Trouble isi forget to turn the app off when I exit the car and once started it continues to use the gps and drain the battery even when the car is off.
Is it possible to enable auto switching on/off of the app when a charging power supply is connected/disconnected? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15409 Location: Bradford, West Yorkshire
Posted: Thu Dec 26, 2013 10:40 pm Post subject: |
I know Dropbox's "camera upload" feature only works when the battery is above 20% so it may be possible to do something. Not sure if we can 'detect' if the phone is plugged in or not but at the least we may be able to say "if the battery is less than xyz% then disable GPS" (as an option).
I'll look into it and see if it's something we can consider. Even if it's just to save people's battery when they forget to stop GPS and don't stand still for 10 mins!
MaFt |
IanS100 Frequent Visitor
Posted: Fri Dec 27, 2013 5:01 pm Post subject: |
I'd find something like this useful on Android, I run CA on a Nexus 7 and have a similar problem _________________ Galaxy Note 4 / TomTom GO : CamerAlert : CoPilot |
M8TJT The Other Tired Old Man
Posted: Fri Dec 27, 2013 5:14 pm Post subject: |
Does not CA stop after 10 mins of no movement? Or is it not switching off the GPS that's the problem? |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Fri Dec 27, 2013 5:40 pm Post subject: |
M8TJT wrote: | Does not CA stop after 10 mins of no movement? Or is it not switching off the GPS that's the problem? |
I have an old HTC Desire (Android 2.2.2). If I leave CamerAlert running with no power to the phone, then the battery is drained within a few hours.
It would be useful for both Android and iOS versions of CamerAlert to determine power level of battery (percentage) when CamerAlert is started and if power level of battery drops a certain percent amount (option set by user) then shut-down CamerAlert as device is not being powered. _________________ Robert.
Garmin Camper 770 LMT-D |
Posted: Fri Dec 27, 2013 5:50 pm Post subject: |
It's difficult to answer that because the few occasions I have left CA running overnight I've come back to a Dead Nexus with a flat battery.
Running GPS doesn't seem to use much juice on it's own so I can only imagine that increased polling is causing the drain - I'll try to watch what's happening & report back _________________ Galaxy Note 4 / TomTom GO : CamerAlert : CoPilot |
Posted: Fri Dec 27, 2013 7:14 pm Post subject: |
My reply should have been more directed at MaFt or a CA coder as a question. because that's how I thought it was supposed to work. Having said that, if it does shut down after 10 mins of no movement, you are likely to drive off after a comfort/meal break only to not have CA running and consequently no warnings. But there is an old adage that finishes up with 'but you can't please all the people all the time' |
AliOnHols Pocket GPS Verifier
Posted: Sat Dec 28, 2013 3:28 pm Post subject: |
Quite a lot of guessing between the lines on my behalf here but assuming there is no movement for 10 minutes, CamerAlert shuts down but leaves the GPS running. I would guess that the GPS is hungrier for battery than CA .
On my Android I use a combination of a couple of apps called SmartActions and Tasker. I should imagine that there are similar apps for iOS to detect a power supply and activate certain apps and then kill these same apps when the power source is lost. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Sat Dec 28, 2013 6:13 pm Post subject: |
IanS100 wrote: | M8TJT wrote: | Does not CA stop after 10 mins of no movement? Or is it not switching off the GPS that's the problem? |
It's difficult to answer that because the few occasions I have left CA running overnight I've come back to a Dead Nexus with a flat battery. |
Perhaps when you are parked at home the phone is picking up your wifi intermittently causing the location to move around - thus CA thinks you are still moving and doesn't shut down?
MaFt |
Posted: Sat Dec 28, 2013 6:18 pm Post subject: |
MaFt wrote: | Perhaps when you are parked at home the phone is picking up your wifi intermittently causing the location to move around - thus CA thinks you are still moving and doesn't shut down? | Does this confirm that it IS supposed to shut down? |
Posted: Wed Jan 01, 2014 8:40 am Post subject: |
Happy new year everyone.
For sone reason I'd imagine there must be a flag somewhere in the software indicating charging status but you guys know far more than I ever would.
The turning off is more useful but this tanker app sounds like exactly what I need, a m going to look it up anyway, but in the event that there isn't an equivalent, it would be great if CA could incorporate the feature. The turning off is more important but the turning would be a bonus.
It's the only reason I leave an iPhone in the car so if there was a way it could run completely automatically it would make the solution perfect.
Thanks for considering this. |
Posted: Wed Jan 01, 2014 4:50 pm Post subject: |
I know that you are planning on using a power source as the trigger but it is possible that unless you have your phone connected to a permanent supply, your phone battery could die out unless you use your car for a significant ammount of time every day and if't connected to a permanent supply, its possible that it is not going to recognise a new power source. do you have a radio with Bluetooth?
If you are able to find Tasker (or similar) on iOS, this is the way I have cobbled together my system -
Everything is triggered by a Bluetooth connection to my car radio-
I enable Bluetooth on on my phone.
I turn the car ignition on, the Bluetooth on my radio is enabled. From here everything is automatic-
the phone pairs to the radio over BT
The BT pairing triggers GPS to switch on
Wait 3 minutes (to get a GPS fix)
Start CAmerAlert app.
Wait 5 seconds
Beep (To draw my attention that CA has started and to make sure it is tracking, if not, I have 1 minute to manually set it to track before the next operation)
Wait 1 minute
Start Navigation app (Which at the moment is Waze).
Switching the car off, kills the BT to the radio and the pairing. Tasker recognises the lost BT pairing and shuts everything down.
So, all I have to remember to do is turn the BT on my phone on. _________________ Garmin Nuvi 2599
Posted: Thu Jan 02, 2014 1:37 am Post subject: |
AliOnHols wrote: | I know that you are planning on using a power source as the trigger but it is possible that unless you have your phone connected to a permanent supply, your phone battery could die out unless you use your car for a significant ammount of time every day and if't connected to a permanent supply, its possible that it is not going to recognise a new power source. do you have a radio with Bluetooth?
Wait 5 seconds
Wait 1 minute
So, all I have to remember to do is turn the BT on my phone on. |
I'm on Android but using "Bluetooth Auto Connect" which switches BT on when put on charge so, ignition on, USB charger receives 12v, BT switches on - I think I'll try Tasker for the rest of the sequence. _________________ Galaxy Note 4 / TomTom GO : CamerAlert : CoPilot |
Posted: Thu Jan 02, 2014 7:26 am Post subject: |
There is a free 7 day trial link on tasker's website. Make sure it does what you want prior to purchase. It works with one of my phones but not the other. _________________ Garmin Nuvi 2599
Posted: Thu Jan 02, 2014 7:36 am Post subject: |
