Pocket GPS World :: View topic - Garmin E-Trex
Garmin E-Trex
martinfbrown
PostPosted: Sun Apr 19, 2009 7:15 pm    Post subject: Garmin E-Trex Reply with quote
I have a handheld Garmin E-trex and Memory Map software. I have connected up okay to my laptop and set up the GPS okay. When I try to upload routes from the e-trex to the laptop, I get the message:time out receiving packet and the upload is not completed. Anyone have any ideas please. Thanks.
Martin
View user's profile Send private message Yahoo Messenger
AllyCat
PostPosted: Mon Apr 20, 2009 12:50 pm    Post subject: Reply with quote
Hi Martin,
Which model of eTrex do you have (some use a serial connection, others USB)?
Have you managed to transfer any data (in either direction) between the eTrex and PC?
To what did you set the eTrex (e.g. Garmin or NMEA, baud rate)?
To what did you set MM (e.g. USB, Garmin, NMEA, baud rate)?
Do you have the Garmin Mapsource software and what version of MM?
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
martinfbrown
PostPosted: Mon Apr 20, 2009 4:25 pm    Post subject: Reply with quote
It is a Garmin E-Trex. I have never had this problem in the past, but I have just re-installed the software, so the problem may have stemmed from there. Did not check baud rate etc, I will check it again. I only tried it on my laptop, I will try it on the desktop pc. Thanks.
Martin
dales
PostPosted: Wed Apr 22, 2009 2:45 pm    Post subject: Reply with quote
For me, the usual cause is low battery power. Freshly charged ones restore the link.
Sometimes, turning off the eTrex and closing down MemoryMap and restarting both seems to improve matters.
Finally (if you're sure your interface settings are OK at both ends (PC and eTrex)) the following usually fixes it for me, with my serial connector. In the eTrex Interface, change the Serial Data Format from Garmin to NMEA and back to Garmin again. The eTrex usually hangs up and goes blank, but I just let it chew things over and it comes out OK, problem fixed.
Dales
