Rowan29a Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: Aug 22, 2004 Posts: 95 Location: North Yorkshire, England
Posted: Tue Mar 03, 2009 12:39 pm Post subject: TomTom Disfunctionality - Again |
Eagle15 wrote: | Anyone tried to 'Operate my Go' using Home yet?
Mine doesn't work. Says the functionality isn't available. |
Yep! They have done it again and released an "update" not fully configured. It does not occur to TomTom that this sort of practice generates intense frustration. The question is "do they care"? The answer is "not at all" otherwise they would not do it. _________________ Mike -
TomTom 750 Live
iPhone 5 16GB, Kavaj "Dallas" case |
jimbo_hippo Frequent Visitor
![](modules/Forums/images/avatars/21077135774339845938047.gif)
Posted: Tue Mar 03, 2009 12:43 pm Post subject: |
OK. Did 275 miles with the new software last night. Generally it seems to have addressed most of the issues.
I did a reset before leaving to be sure I was starting with a blank canvas. I had a few podcasts I wanted to listen to so had the FM transmitter running too. One junction I always got a stutter at was the roundabout leaving the A1 and joining the M18 and it didn't hick at all.
All in all worked fine throughout the journey. I had USB power applied so no idea if running on battery has any implications.
It would also seem that the hicking of MP3 playback when issuing commands has gone now although I was listing to voice podcasts so it isn't as apparent. However I'm pretty sure it was all smooth.
I still have the irritating (but not life threatening) issue that after an ALG screen I seem to be 800yds to the left in a field for about 2 seconds but that's always been there for me.
Also still have the fixed volume issue in the jukebox with a useless slider which still annoys me as it's sloppy programming.
The same journey last week had me cursing and resetting all the way but it seems that at least we're somewhere near where we should have been several months ago. I wouldn't say I'd like to thank Tom Tom as this is well overdue but at least it's a step in the right direction and might prevent me from throwing the toys out of the pram on here quite as much. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
Andy_P Pocket GPS Moderator
Posted: Tue Mar 03, 2009 3:33 pm Post subject: |
jimbo_hippo wrote: |
Also still have the fixed volume issue in the jukebox with a useless slider which still annoys me as it's sloppy programming. |
Hi Jimbo, me again
I know we've been here loads of times, but just in case anyone else is confused...
TT have decided to fix the feed to the FM output at maximum level so if you use FM, the volume slider on the Jukebox page appears to do nothing.
However, that is a standard screen, and the slider is just a duplicate of the MAIN volume slider, so it still affects the navigation voice level.
If you are using some of the other outputs for the music (set miles away in "Speaker Preferences") then the slider DOES still have an effect.
In detail, if you have the navigation directions on the internal speaker, here is what happens with music routed to the various outputs in Speaker preferences:
Internal speaker - Volume slider affects BOTH nav. directions and music
Bluetooth audio - Volume slider affects BOTH nav. directions and music
Line out socket - Volume slider ONLY affects nav. directions - (DAFT if you want to listen to music on headphones when not driving - it blasts your head off!)
FM transmitter - Volume slider ONLY affects nav. directions - (on Jimbo Hippo's radio, this makes the FM distort badly.)
Other notes:
1. The music still goes to the line out (at full volume!) when it is selected to FM or Bluetooth, but not when set to internal speaker.
2. The music defaults back to the internal speaker whenever the Bluetooth connection is lost (i.e. whenever you turn the engine off in my car!)
3. The music ALWAYS pauses for nav. directions, except on Bluetooth where it is a user-setting whether to pause or not. Why it can't be an option on the other outputs is a mystery.
It's a mess.... |
Posted: Tue Mar 03, 2009 3:59 pm Post subject: |
Yeah Andy. My version is somewhat simplified and your info is spot on. And yes it is a mess. It still gives the impression that it adjusts the Jukebox volume which is why it irks me. It's just a badly thought out method which is (I believe) the result of sloppy programming. Looks like they stilll haven't looked at your rather sweet mock up of how it SHOULD be ! :-)
Regarding the clipping, in my Zafira music is pretty much unplayable unless I normalise it or reduce the gain in a software app which I'm not prepared to do for all my MP3s.
Last night I listened to several podcasts. An American F1 chat which I like a lot. Fighting Talk from the BBC, Johnathon Ross from the BBC and Sany Wotsits News Quiz thingy. All these play fine even when there is a music clip. But then the Chris Moyles Podcast (also from the BBC) clips like hell so it must be a small tweak of gain which 'overdrives' the input to the Zafira stereo.
In the Motorhome I use line in and my wifes 525i has built in satnav so I've never tried it. _________________ Tom Tom GO 720
Holux GPSslim |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Tue Mar 03, 2009 5:43 pm Post subject: |
yep done about 150 miles and all works wonders for me ,even loaded up a heck of a lot poi show poi's and although it did show signs a lagging it was no where near as bad as before ...did find it was a little slow on round about but again now where near as bad as before
so for me it's a good upgrade ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ TomTom 5001 |
Posted: Tue Mar 03, 2009 6:04 pm Post subject: |
I've not been out today, but while double checking the various audio outputs for my previous post, I left it looping on a short demo route with some music playing.
I was rather disappointed to find it slowly got worse....
It never stuttered, but I had more and more repeated words - "After four, four, four hundred yards...." and eventually more and more repeated chunks of music at the times when navigation directions sounded too.
And I had such high hopes this time! ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
AndyVaughan Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_matrix_014.jpg)
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Tue Mar 03, 2009 8:57 pm Post subject: |
I don't check in for a day and TT go and release an update!
Typical.
Will download and try out with TTS6 as I have a few long journeys tomorrow.
Fingers crossed!
Andy |
LT Regular Visitor
![](modules/Forums/images/avatars/gallery/familyguy9.jpg)
Posted: Tue Mar 03, 2009 11:25 pm Post subject: Crashed and keeps rebooting. |
DISASTER.
Loaded the new software this morning. Set the 730 to Sheffield from Lancaster. Got there ok. Match postponed so decided to go to another. Tried to set it to go to the next destination and it seemed to take ages. Then it went off and rebooted, and again and again and again....
Couldn't turn it off either. Occasionally it would go on and show where I was but as soon as I tried to navigate anywhere it crashed again.
Tried to reset it but same thing still happens.
Tried to restore it from previous save and that has failed. Now I'm knackered because I'm going to Dagenham on Saturday supposedly...
Any suggestions??? |
dhn Frequent Visitor
Posted: Tue Mar 03, 2009 11:48 pm Post subject: |
Think maybe running the Clear Flash tool from here may help?? _________________ David |
LT Regular Visitor
Posted: Tue Mar 03, 2009 11:53 pm Post subject: |
Thanks for that, but the problem doesn't appear to be any of the ones listed for which that tool would put right... |
Posted: Wed Mar 04, 2009 12:09 am Post subject: |
But what do you have to lose??? _________________ David |
Posted: Wed Mar 04, 2009 12:13 am Post subject: |
LT wrote: | Thanks for that, but the problem doesn't appear to be any of the ones listed for which that tool would put right... |
Ignore that... Try it. It has fixed at least one common problem that isn't on their list.
It won't do any harm anyway.
Don't forget that it is very easy to replace the operating system files manually too. So most problems like this are easy to fix.
But ALWAYS backup with Windows Explorer (NOT Home), first. |
LT Regular Visitor
Posted: Wed Mar 04, 2009 12:39 am Post subject: |
Well I've given that a go, (pardon the pun!) but it's still a no go (pardon that pun too!)
Still doesn't want to know if you try and navigate somewhere and just reboots again. |
jmfarrell Occasional Visitor
Posted: Wed Mar 04, 2009 11:38 am Post subject: Lost spoken instructions |
I installed 8.302 last night hoping it would fix the audio stutter issue.
On a trip from Cambridge to Watford this morning, all seemed well until approaching J5 on the M1 Southbound (A41 exit for Watford).
Kate spoke the 'A' of "After XX yards ..." but at that moment the ALG image appeared on screen and Kate fell silent.
I didn't get any more spoken instructions after that until rebooting at my destination
Anyone else seen this? _________________ TomTom Go 720
App: 9.430.890926.1, OS: 842337
GPS: v1.20, Boot: 5.5120
Map: Europe West v875.3613 |
Posted: Wed Mar 04, 2009 11:47 am Post subject: |
JM, out of interest were you runing on battery or plugged in? _________________ Tom Tom GO 720
Holux GPSslim |
