Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 16, 17, 18 ... 33, 34, 35  Next
PostPosted: Wed Feb 25, 2009 6:28 pm    Post subject: Re: FFUIERROR: Parse error [layer expected] Reply with quote
voyo wrote:
I own the FS Pocket loox560 with windows mobile 5 and a VGA screen
IGo 8 version 8.0.0.31442
I think that linknet will confirm that Ultra 6 is for IGO 8.3.2.64029 not your earlier version Sad . He may have an Ultra skin that works withy your version of Igo 8 Very Happy
linknet
PostPosted: Wed Feb 25, 2009 7:10 pm    Post subject: Re: FFUIERROR: Parse error [layer expected] Reply with quote
after applying the Igo 8 Ultra Skin 6.0.10 i have got this message at start.
Version 6.0.10 only supports:
iGO8 Version 8.3.2.64029
iGO8 Version 8.3.2.64873
However version 5.0 of the Ultra Skin supports:
IGo8 Version 8.0.0.31442
So if you download that and the relevant voice files it should work fine. Smile
linknet
voyo
PostPosted: Wed Feb 25, 2009 7:34 pm    Post subject: igo Reply with quote
thank you for the fast response.
Is there any possibility to have the 5.0 version working in VGA?
linknet
PostPosted: Wed Feb 25, 2009 8:42 pm    Post subject: Re: igo Reply with quote
IGo8 Version 8.0.0.31442 doesn't fully support VGA so neither does the Ultra Skin version 5.0.
If you want VGA support then upgrade free to 8.3.2.64029 and use the Ultra Skin version 6.0.10 which does support VGA. Wink
linknet
mxmaciek
PostPosted: Thu Feb 26, 2009 2:52 pm    Post subject: Reply with quote
saphir78 wrote:
Oh nooooo ...
and do you think that using WVGAFIX3 to change resolution of my omnia in 240x320 i will can use your skin ??
WVGAFIX3 is a little soft to change resolution.
If you was able to find WVGAFIX3... you shall try to find the kikker skin with Omnia. It's a clone (with all adantages - like speedcam warnings - and disadvantages - like not everything works perfect) which works perfectly with resolutions not supported by Ultra skin.
linknet
PostPosted: Fri Feb 27, 2009 12:12 pm    Post subject: Reply with quote
Added Version 6.0.11 Smile
Increased the "Maximum Search Radius" setting for the "Pop-Up Information Panel" to 10 km. This is really only to make it easier to search for user POI's with "Display Visible POI's Only" enabled.
Added a fix for the second route event background occasionally displaying with no information.
linknet
vangelis_73
PostPosted: Fri Feb 27, 2009 1:01 pm    Post subject: Reply with quote
Thank you Very Happy
Regards
plaktoets
PostPosted: Fri Feb 27, 2009 3:52 pm    Post subject: Reply with quote
Hi, i have had a longtime issue with iGO on my HTC Kaiser/ TytnII. I wasn't able to put my device into standby mode using the power off button. The screen would start to blink on and off. Recently i upgraded to R3 and the problem was gone - however as soon as i installed the ultra skin the problem returned. Now i know why i had this problem and others didn't - i've always been using the ultraskin. I can confirm that the problem doesn't exist with the default skin that comes with igo.
Any chance this can be fixed? It's a rather anoying issue - when i'm on route and i want to take my phone with me on a stop i have to completely exit the application in order to get my phone into stanby mode.
Thanks in advance.
-edit: starting to have doubts - right now my screen goes back one just once before going into standby - not so sure that behaviour is different wiith the default skin.
linknet
PostPosted: Fri Feb 27, 2009 6:33 pm    Post subject: Reply with quote
Thanks in advance.
There's nothing in the Ultra Skin that would affect the standby behaviour of iGO8, that's determined totally by the iGO8 executable. Confused
If you still think that the skin is the cause then let me know and I'll look at it more closely.
linknet
iggykh
PostPosted: Sat Feb 28, 2009 10:30 am    Post subject: Reply with quote
Hi Linknet,
In the last versions of your skin the POI visibility distance is noticeably increased. The minimum distance is now 1000m which used to be 500m.
It was intentionally or by mistake?
linknet
PostPosted: Sat Feb 28, 2009 12:25 pm    Post subject: Reply with quote
iggykh wrote:
Hi Linknet,
I only ever use these settings for user POI's and therefore needed higher values to be able to locate them on the map more easily.
For version 5.0 of the Ultra Skin I used to maintain two versions, one for my own use and one for public use. For version 6.0, I decided that this was too much work, and just created one version with the following changes:
500m ---- 1000m
1000m ---- 5000m
5000m ---- 15000m
30000m ---- 30000m
I only use the 15000m and 30000m settings so could change the lowest setting back to 500m if it causes a problem.
linknet
iggykh
PostPosted: Sat Feb 28, 2009 3:49 pm    Post subject: Reply with quote
linknet
It would be nice to have the 500m settings back and also the 1000m, if this is not too much trouble...
thanks
linknet
PostPosted: Sun Mar 01, 2009 5:42 pm    Post subject: Reply with quote
Added Version 6.0.12 Smile
Added an additional "POI Icon Visibility Distance" setting to the Manage ► POI ► Edit menu to give:
Close ► 500 m
Nearby ► 1000 m
Medium ► 5 km
Far Ahead ► 15 km
Satellite ► 30 km
linknet
iggykh
PostPosted: Sun Mar 01, 2009 7:27 pm    Post subject: Reply with quote
linknet
scope
PostPosted: Tue Mar 03, 2009 4:50 pm    Post subject: Reply with quote
Linknet: If you are not going to back down from your view on changing the speed camera warning system to work as it did in v5, could you atleast give us the option to switch sound on/off for the different types (mobile/static, etc).. This way we would get beeps (if overspeeding) for say static, but not for mobile, though mobile speed camera icon would show on the screen.
Ideally though I'd like the return of "Static speed camera, 40mph", like v5. Smile
Another feature request I've got is: time till next turn (recalculated based on your current speed).. I use this on GJ skin, and find it quite useful to know in minutes:seconds how long until the next turn.
Page 17 of 35
22.055 (29 May 24)
