Pocket GPS World :: View topic - Colorado 300 Navigation settings
alancragg
PostPosted: Wed Aug 13, 2008 12:45 am    Post subject: Colorado 300 Navigation settings Reply with quote
OK, I recently purchased a Colorado 300 to replace my trusty, battered, but still serviceable Magellan 3000XL, installed TOPO GB V2.0 and I am very impressed! But...
I also purchased CityNavigator for UK and Ireland, thinking the unit would replace my old HP 2215 with Tom Tom 5.0 for in the car, the only problem is (and I am probably being dense here...) I cannot get the unit to navigate using the recognised motorway routes like the Tom Tom. To go from Kent to Wales the unit tries to take me through London rather than round the M25, ie same as 'Shortest Route' on my Tom Tom, and I cannot find a setting to change it.
Any help gratefully received Smile
Zenelia
Banned
PostPosted: Wed Nov 26, 2008 9:48 am    Post subject: RE : Colorado 300 Navigation settings Reply with quote
i have some information related this topic, i will share with you later because i am chaking this.
eyeQue
PostPosted: Wed Nov 26, 2008 10:06 am    Post subject: Reply with quote
It is not the fault of the Oregon but the CityNavigator software.
I use the route Maidstone to Wales and have had the same problem with other Garmin units:- Oregon, Colorado, 60CSX, iQue!!!
There are two faults on the route mentioned - either it takes you through London or Bracknell, it does not not like M4 J4b [M25]. It seems to have an in-built aversion to M4 J4b!! Perhaps as it has been so bad at the new Heathrow treminal entrance for so long!
Just create a via point/waypoint on the route and store that route in the unit.
Keep the two waypoints as a permanent features.
M4 J4b [E]
M4 J4b [W]
A real problem with the Oregon is that has only 3 options for vehicle type - truck and bus are missing. I always in the past used 'truck' as it saves some bad routing!!!!
My waypoints:-
M4-J04bE-M25----N51.49442 W0.50452
M4-J04bW-M25---N51.49421 W0.50378
Garmin Oregon 300 + Garmin iQue 3600
My Zoned Speed Camera Icons, available here.
philpugh
PostPosted: Wed Dec 03, 2008 5:43 pm    Post subject: Reply with quote
Again the problem would be with the s/w - not the unit.
I thought the bus/lorry settings only affected the ETA calculation and not the routing Confused
Phil
eyeQue
PostPosted: Wed Dec 03, 2008 6:00 pm    Post subject: Reply with quote
The setting 'Truck' is missing from the Oregon unit. I have had it in most units in the last five years. The only options now are Car or Motorcycle/Pedestrian/Bicycle
The setting is in MapSource on the PC with CityNavigator [Bicycle/Bus/Car or Motorbike/Delivery/Emergency/Pedestrian/Taxi/Truck]
On the previous units the setting 'truck' has navigated different routes using CityNavigator so has been invaluable.
The Fault at the M25/M4 juction has been present for three years and in all my units. That seems to be a s/w problem with CityNavigator rather than the units.
Have you found the problems with your Garmin units?
